Took my 1981 CJ7 in to get the alignment set today. (after putting new Rugged Ridge Tie Rods and Drag Link a few days ago). They were able to set the Camber and toe within range, but were not able to adjust the Caster within range with the current set up. They suggested that this may not be a big issue as Caster doesn't impact tire wear as much as the other adjustments, but that the vehicle may not self-center the wheel after turning a corner. This all makes sense to me based on their explanation. They said that if I wanted to correct the Caster I'd need to install some bushings that would give the proper adjustment.
What I'm wondering is :
1) how important is it for me to fix the caster? (left is at 2.1 degrees and Right is at 2.4 degrees after the alignment)
2) What are the correct bushings that they reference and is there a good link to how to install and adjust these?
Thanks!
Thanks!
