My wife calls me from work Weds and says the CEL on my 96 4.0 is on but it's still running good. When she got home in the cold/dark I put my scanner on it and it read P0420, "Catalyst System Efficiency Below Threshold, Bank 1". From data it read; 02S11(V) = .020-.040 moving back forth slowly, and 02S12(V) = 1.1-1.2. also changing slowly. I know you aren't supposed to have any o2 sensor reading above 1.0 if it's working correctly. But I installed a new NTK downstream/cat o2 sensor about a year ago w/whole new exhaust but didn't change the front/downstream sensor.
I thought this whole CEL/code was suspect since I just sprayed Fluidfilm rust preventative on the bottom the day before. Sure enough I had sprayed the downstream o2 sensor connector by the oil pan and in taking it apart there was Fluidfilm on one pin and the female hole it fits in. I sprayed electric contact cleaner on the inside of the connector and also on the wires going into the connector ends since there was Fluidfilm all over the wires going into the connector. I used a heat gun to dry all the cleaner out then put the connector back together.
Whoops, I had forgot to disconnect the neg cable on the battery when doing this work on the connector and my mistake. At least I didn't have the key on and then disconnected the battery for 5 min to let the PCM reset itself.
It was running smooth when starting it but it soon became rough and almost wanted to die. And my data readings are now screwed where it reads; 02S11(V) = .000, which I assume my downstream o2 sensor isn't working at all, and 02S12(V) = 1.02-1.04 where it's still above 1.0. Then code P0171, "Bank one system too lean", pops up with ST FTRM reading 32.8. Just great!
I do have a new NTK 23121 downstream o2 sensor and guess my 1st step is to install it. Is there a correct way to read the voltage coming out of the downstream sensor engine side connector pins to see if it's getting voltage? There was a bunch of Fluidfilm on this wiring which goes into the connector itself and hope I cleaned it out of the inside where the wires attach to the pins. Just seems strange all of the sudden this front o2 sensor is reading .000 and not working.
Thanks for any input!
BTW, I did test the cat using my new infrared temp gun and the front of the cat at the welds read 305-310 degrees while the back at the welds read 320-330 degrees. The temp difference is supposed to be 100 degrees with the back of the cat being hotter. But this may be a flawed test/mute point if the o2 senors aren't working correctly with lean fuel trim. Plus I only had my 4.0 at idle when you're supposed to have it at 2K rpm to do this cat test correctly.
