4.7L exhaust manifold bolts info
25K views 22 replies 12 participants last post by  superheady
Just because I had a lot of difficulty finding this info, I thought that I would post it and maybe it would save somebody some effort. It may be only relevant to 2003-04 WJ's. Not sure about that.
On my 2004 4.7L HO, there are 3 different bolts used to secure the exhaust manifold to the head.
Part numbers in order from top to bottom are:
a) 6508219AA
b) 6507746AA
c) 6508220AA
The FSM and Parts Catalog has images indicating 3 different bolts, but only provides two part numbers (a and b, and indicates that a and c are the same part).
As you can see from the following image, c appears to be necessary because the heat shield is "deeper" on one end - that is, the mounting holes are not on the same plane.
Now it may be possible to mount the heat shield using only a and b - I'm not sure about that. I haven't tried. *edit* tried it - you have to have all 3 bolts to fit the heat shield.
Also, I've been told by the dealer that all of these bolts are now hardened steel, due to failures from the originals, but I have no way to confirm that. And part numbers for a and/or c appear to have been updated. The part numbers above were provided to me by the dealer. The nuts for the stud are not included.
Interesting. Which studs were used? And any chance that they had been previously replaced?
I don't see how my heat shield could have fit properly without the combination of the three bolts. I guess it could have been attached with the longer studs on both ends, but it would've been a poor fit.
mtsumedi said:
How long did it take djpeters?
It actually went exceptionally well. Everything came apart good. It's tight to work on and a 6" long, 6 point box end wrench is a must. My two back studs were broke, one I got out with vise grips before taking the manifold off and the other came out after getting the manifold off. I had the manifold resurfaced ($50), and new gasket and hardware from dealer ($75). In total, taking my time, about 4 hours. Very happy. My Jeep is quiet again!
#17 ·
I just wanted to make a correction about my previous post. I was wrong on saying my studs were all the same. The OP is exactly correct on the sizes. My back two studs were broke and it wasn't until I was cleaning up my bench just now that I held the broken pieces together and went hmmmm....they aren't the same. But, my heat shield still went on fine so I'm going to leave it.
#19 ·
No part number needed for the updated gasket at the dealer. When I replaced mine they gav me the updated version. Due to mandates if a part number is updated they phase the old gaskets out as it is a liability for them to sell you a part that is now void in their stock. On a side note, rock auto sent me the updated gaskets as well when I ordered what I needed to replace my headgaskets. I'm not sure about the parts stores however as I did not order it from them. I can only attest for the dealer and rockauto.
#21 ·
I just did this project on my 2004 4.7L, and put together this image for people to have as a quick reference. I wanted to also make note that I did not have any washers on my bolts when I disassembled the exhaust manifold and heat shield, but this might have only been on certain years.
#22 ·
What is the thread size on the studs?
Anyone know what the thread size is on the head end of the stud? M6?M8? They look to be all the same. From the pictures with the tape measure they look to be 50 mm long under the bolt head.
I am considering using stainless studs and brass nuts on the exhaust. Will never have a problem again with rusty fasteners.
#23 ·
Great info here. Appreciate this forum so much.
I had this issue for a couple weeks. Noticed on start up and acceleration that I had the sound of an exhaust leak, or an engine tick. Thought it could have been a spark knock, but then under inspection I realized my manifold heat shield was off in the rear of the engine. Sure enough, both rear bolts had sheared themselves off. So I went to the dealer got the 2 replacement bolts since I didnt want to do the whole job right now, weather sucks.
I was one of the kucky ones. I was able to twist the broken stud out on the bottom with my fingertips. The top I jad to use some very small vice grips to twist it out. But, I was able to complete the entire job without having to remove the manifold or loosen any other bolts. Literally just got the studs out, put in the new bolts and replaced the heat shield. Now it sounds good as old.
