Parts List for Exhaust Manifold Job on 4.7 v8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Parts List for Exhaust Manifold Job on 4.7 v8
TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ March Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATEFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 08-24-2013, 10:49 AM   #1
billzcat1
Chicken in a Turkey Suit
2003 WJ
Hi Fellas -
My WJ picked yesterday to crack an exhaust bolt/stud and create the typical 4.7 massive exhaust leak. So I'm gearing up to do the job, going OEM on the parts and replacing all the hardware. I have the OEM parts catalogs but they are not real helpful in telling me how many and what kind of fasteners I need. And of course I can't see anything without fully disassembling the Jeep and I can't have it torn down for a week waiting for parts.
I've figured out I need...
53034030AC - manifold gasket
53034029AD - manifold gasket
6506012AA x 4 - hex bolts from downpipe to manifold
Where I'm confused is how many bolts and how many studs hold the manifolds to the heads. I don't want to just order everything and see how it turns out. At $1-3/pc and 20 pieces needed, that adds up quickly.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2013, 06:25 PM   #2
coopdc78
Idk if it helps. But there are 8 per side and they had all of mine in stock at the dealer for I believe 2.50 a piece
2004 overland 3 inch lift bilsteins 5100.. Addco sway bar. 265/70/17 nitro Terra grapplers
coopdc78 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2013, 09:54 PM   #3
billzcat1
2003 WJ
Were they all the same? If so, were they bolts or studs?
Unread 08-25-2013, 05:50 AM   #4
coopdc78
Oh yeah. Forgot about that. I believe they were all studs but the ones that hold on the heat shield have more exposed thread yo hold the shield on
Unread 08-25-2013, 10:03 PM   #5
billzcat1
2003 WJ
I think I've got it figured out. Been reading lots of threads...finally grew a brain and dug up the service manual.
Final answer...
The leading and trailing cylinders on each head have studs and the middle two cylinders have bolts.
I'm going to update with a complete list of hardware needed for the job...
Unread 08-25-2013, 10:09 PM   #6
billzcat1
2003 WJ
A list...
6505257AA x 4 - studs for manifold-to-head
6504340 x 8 - hex bolts for manifold-to-head
6504331 x 4 - studs for manifold-to-head
6505316AA x8 - nut
In case you're wondering why I'm replacing EVERYTHING... I don't want to do this job twice. I know from past experience that a lot of the fasteners on exhausts and manifolds will wind up getting damaged during removal. Rather than getting halfway done and getting stuck due to broken/missing fasteners, I'll just be expecting to replace it all.
Unread 08-26-2013, 06:59 AM   #7
webby88
Originally Posted by billzcat1 View Post
A list...
6505316AA x8 - nut
I just did this job about a month ago, called a random dealership and ordered all the parts over the phone, came out to $35~ after shipping for all new bolts and new gasket.
I see you got the list together so you don't need mine.
Ill just say this, I did only the drivers side in about 1.5 hrs without air tools nor lift, every bolt came apart surprisingly easy and reassembled nicely.
Good luck!
'03 Grand Cherokee Limited 4.7 QD - DD
'00 Grand Cherokee Laredo 4.7 QT - Shes Alive!
webby88 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 10:19 AM   #8
billzcat1
2003 WJ
Yeah, the total for both sides came to $74 + shipping from MoparOnlineParts.com. I ordered everything down to the nuts - which surprisingly enough were the most expensive part. I'm not unhappy with that price for all OEM parts. I might be a little unhappy with the job though. I'm going to do both sides just to be sure I don't have to do it again.
Unread 08-26-2013, 12:01 PM   #9
Galaxie500LTD
Nice looking list. I'm looking forward to hearing how it goes for you. You guys in the USA are lucky, up here it was $45 for just the nuts and bolts from the Y-Pipe to the manifolds (4 nuts, 4 bolts).
In your list, are the nuts for the Y-pipe in there? They have the flange attached to them. Is this them?: 6505316AA x8 - nut
I'm pretty sure my manifold(s) are leaking, the sound used to be a tap... but now it's more clacky sounding... I can't tell where it's coming from exactly. Does yours sound ticky?.... or clacky?
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 01:14 PM   #10
billzcat1
2003 WJ
I did not see the nuts listed in the parts fiche and had assumed (falsely?) that the manifold was threaded to accept the bolts. Most everything I have worked with in the past has had studs in the manifold and then nuts on the downpipe so this seemed off. I'll look into it further when I get home.
Unread 08-26-2013, 01:44 PM   #11
Galaxie500LTD
According to my bill the part # is 06503231 at $6.35 each.
-It's good and bad that they're not attached I guess (no way to break the studs)... but if they bust off the tab on the nuts and start spinning it's pretty hard to remove them. I managed to get a set of mini-vice grips on the one that broke off the tab (flange). The studs (bolts) have a funny thread that bite into the nut so they can't vibrate loose once tightened.
Unread 08-26-2013, 02:32 PM   #12
Double E
2000 Laredo V8
Double E's Avatar
I've never heard of the passenger side manifold studs snapping but your philosophy is thorough if not ambitious. Agree that the remaining stud will probably twist out by hand.
The downpipe nut is a bear... spray it ahead of time...
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 03:22 PM   #13
Galaxie500LTD
I was just guessing as to why Chrysler thought it was a good idea to not have permanent studs attached to the manifold to attach the Y-pipe (or downpipe?... I think we're talking about the same thing)... I really don't know why they did it that way
Unread 08-27-2013, 11:24 PM   #14
billzcat1
2003 WJ
I know, right?
I searched the parts fiche for that nut p/n you posted. Came up as a flanged 10mm nut used to hold on the bracket for the shift cables. I haven't found any mention of the nuts for the downpipes. I have been pretty unimpressed with the OEM parts catalogues for the WJ thus far, the ETKA and PET catalogs were much better.
Looking "forward" to having this fixed though.
Unread 08-30-2013, 09:03 AM   #15
Galaxie500LTD
Here's what those little suckers look like:
http://www.jeep4x4center.com/mopar-p...t-6503231.html
I would like to have a set of nuts and bolts done up in stainless. I have to remove my Y-pipe again when I do my exhaust manifold gaskets. I have a good chance of getting them off this time as it's only been a year since I replaced my oil pan.... but I'm really not looking "forward" to it at all... it's one ugly mutha of a job.
I highly recommend getting one of these:
Take your time, be patient and Best of luck to you!
Let us know how it goes!
