231HD build - JeepForum.com
post #1 of 28 Old 11-19-2011, 08:00 PM Thread Starter
skain8
skain8's Avatar
Wj 231HD build
Quick and dirty parts list to build a junkyard 231HD. I've seen a bit of conflicting information on this and other forums, so I will share what I have learned in piecing mine together. First off, there is no "231HD" case from any Jeep or Dodge vehicle that is simply plug and play. There may be other varyiations to this, but below is what I know will work for your WJ. You can either piece it together yourself, or buy a pre-made, brand new case from JB conversions that includes the items listed below:
1. 231D out of a '98 - '01 Dodge 1500 pickup. This will include the 1.25" wide chain (231J's (jeep models) are 1"). This case will also include the updated and stronger aluminum shift forks. Prices vary anywhere from $150+ depending on your region. Check www.car-parts.com.
2. Source a 6 pinion planetary from a late 90's model dodge transfer case (i.e. 241D, 241DHD). Late model is critical so the gear cut will match. The 231D (and 231J's) includes a 3 pinion planetary that is rated at 600 ft/lbs torque. The 6 pinion is rated at 1,400 ft/lbs torque. I found several used on eBay varying in price from $75+. JB conversions can get you a new one for $200. I opted for used.
3. HD Slip yoke eliminator. JB conversions or Advance Adapters is your best bet here. The 231J/D SYE is the same. Includes a 32 spline output shaft, which nets you an increase of 54% torque capacity over stock output shaft. Can go super shorty or regular. For long wheelbase WJ's, there really is no reason to go super shorty. Regular SYE will run you $200. I opted for JB due to a couple of minor advantages that I perceived over AA. Both are very good, however.
4. Swap your input shaft over from your 242/247 and it will match perfectly to your trans.
5. Miscellanous:
a) No 231 bezel swaps over so you'll need to either do nothing or ghetto-fab some labels. The 231HD shift pattern is opposite from that of a 231J, as follows: 4L - N - 2 - 4PT.
b) You may have to modify the linkage arm, depending on your donor case -- there are a few good threads on this. Note: you do NOT have to modify the linkage if you swap the linkage from your 242. A 231J or 247 linkage will not work. See pic of 242 linkage arm, which is direct swap.
c) You will also need a 1 1/4" freeze plug to plug the speedo port, which is a few dollars at any local parts store (speedo port is nice b/c if you consider an axle swap down the road, you can always run speedo off the transfer case and not the axles). Advance Adapters offers a billett plug with the 231j style horeshoe retainer. I opted for this over the freeze plug, which apparently AA was seeing some issues leakage-wise. See pic of billet plug/retainer.
d) Some 231d's use a vacuum switch for the dash indicator light. The 242 switch is a direct swap, but the detent is longer so the dash light is not accurate. Either leave it alone (I think you should know whether or not you're in 4wd or not , or you can buy a 231J 4wd switch and swap it in by splicing the wire to the new plug. Threads are all the same.
e) Alternatively, you may be able to swap in a Dodge 241 (basically a 231HD) which has 6 pinion planetary, the wide chain, etc.., but the 241 SYE kits are much more pricey. Plus, I am not 100% sure if the input shafts are a direct swap.
Total should run you about $500 in parts. JB's 231HD is $1,275.
Hope that helps.
242 linkage (w/4wd switch in background) + speedo housing plug pics:
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #2 of 28 Old 11-21-2011, 01:35 PM
YZ212
2003 WJ
Excellent, thanks!
03 Limited 4.7 4" IRO Long arm rear 4.5" custom radius arm front Currie Fab 9" hp front
247-231 swap BFG TA KO 315/70/17 Black Rock 909 Type D wheels 17x8 5x5 and 5.5 bolt pattern 4.5" backspace
YZ212 is offline
post #3 of 28 Old 11-21-2011, 02:29 PM
jusjammmin
always great info from this man
jusjammmin is offline
post #4 of 28 Old 11-21-2011, 02:49 PM
Trevino
Good info, thanks man. By any chance do you know the cut off years for 231 cases that are compatible. A buddy is offering me his old 231j out of his 92 yj for free. Not sure if it will swap in though...
Trevino is offline
post #5 of 28 Old 11-21-2011, 08:31 PM
patrick983
nice to see someone do this. just curious why you didnt just start with a 241d or was it an availability issue? i know they are pricier but have the gearset and chain already.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #6 of 28 Old 11-21-2011, 10:43 PM
smunns
I think you need like a '95+ NP231 with the later gear cut to swap input shafts.
smunns is offline
post #7 of 28 Old 11-23-2011, 01:23 AM
Volcom02Wj
Great info! I think I am going this route over the 242.
-COLE-
02 WJ Limited, 4.7L H.O. v8, 6.5" IRO CP Long arm kit, 35x12.50x15 Goodyear Wrangler MTR Kevlar's on Cragar soft 8's
Volcom02Wj is offline
post #8 of 28 Old 11-23-2011, 05:01 AM
98318242
Sweet so you have this setup in and running now? Any pics of the assembly?
98318242 is offline
post #9 of 28 Old 11-23-2011, 09:23 AM
sandfreestyle
I went this route as well and I am very happy. Mine was a little more then the $500 quoted above but I also did a little more to it (rebuild kit, spare 247 input shaft, SS SYE kit). When I did the build the cost came out to about $800 for just the TC and no drive shafts. Totally worth it IMO.
04 WJ V8 HO, 545rfe w/ shift kit, NP231HD w/ SS SYE, TW drive shafts, 4" RCX, 255/75/17 moabs, 55w HID projectors, Cherry Bomb Vortex muffler, Superchips, bored TB, HD Tie rod and Drag Link, IRO Steering Equalizer, Dual steering stabalizers, Homemade Sliders, 4 Hella FF75 55w HID Light bar...
“The corpse’s crimson bitter tears flow and mingle through the endless sand feeding the chaos in me and making me stronger”
sandfreestyle is offline
post #10 of 28 Old 11-23-2011, 09:59 AM
WJflexLJDreams
You'll need a '97 or newer 231J. I've looked into the older models, they won't work.
WJflexLJDreams is offline
post #11 of 28 Old 11-23-2011, 12:00 PM
Trevino
Well I guess the 231 I had in mind is a no go then of well. Probably just going to stick to the 247 for a while longer then
Trevino is offline
post #12 of 28 Old 11-23-2011, 01:37 PM
WJflexLJDreams
You and I both brotha! I had an opportunity at a similar 231 and it didn't match up. 247 it is.
post #13 of 28 Old 11-23-2011, 02:02 PM Thread Starter
skain8
skain8's Avatar
Unless you're have an opportunity to get a 231j for practically nothing, it makes much more sense to source a 231d.
skain8 is offline
post #14 of 28 Old 11-23-2011, 02:13 PM
rockcrawlernut
Very good a lot of great info. Thanks! The price difference is a lot but is it worth the extra money up front for a bolt in unit??
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #15 of 28 Old 01-02-2012, 04:00 PM Thread Starter
skain8
skain8's Avatar
Updated for content/pics re: 242 linkage & speedo housing.
skain8 is offline
Stereo Build towerdude WJ Grand Cherokee Forum 70 11-07-2011 06:49 PM
Possible WJ Build GrCherokeeL WJ Grand Cherokee Forum 24 04-10-2011 04:06 PM
'02 WJ 4.7 Re-Build/Upgrade nextphase2000 WJ Grand Cherokee Forum 44 03-18-2011 05:39 PM
Help me with the parts I need for D30 build. DirtyThoughts WJ Grand Cherokee Forum 0 05-09-2010 08:12 AM
