I recently purchased a 1981 Jeep CJ5. It has some pretty interesting markings. I am sure they aren't original. That being said, is there a way to tell what trim level it is, and if it truly matters when repairs or anything else are done?
Those are just stickers put on by a previous owners.
Much has been changed on that, paint, bumpers, flares, etc.
There should be a metal tag on the firewall, next to the brake booster with some numbers that will show the original color, and interior style color, but thats it.
Post a bunch of pics, both inside and outside, we can probably help give you an idea of what it was, and or what had been changed
Thank you for teaching me how to locate that. I found an original Jeep color code online from 1981. The color code i am pretty positive, is OK. I will know more tomorrow once I get a chance to clean it off. I just now got a chance to really look at it.
I wish those were stickers haha. They are stenciled I believe. I also think, this is the factory color. I will get all of that when I get home. I am traveling, and have been away from it for 9 days. Only got to even look it at it for 2. So I am literally foaming at the mouth to dig into it. It will be my daily driver, so I want to make sure it is good to go. I figured, here is a great place to start. Thank you.
CJ
That one is a Besttop, I believe fairly new. It came with a bikini top, and a top that has the corners, and no windows. It was owned by an old guy who towed it behind his motor home. He recently decided when the registration expired, he told his son to sell it. I got lucky. 115k original miles. He said half are tow from him not disconnecting it right. So we will see.
Welcome from fellow Utahn exiled to West Texas (Air Force plan).
Cool Jeep! I was also thinking there was something familiar about those mountains, and then I saw your tow vehicle's LP. Looks like you're toward the southern end of the Wasatch Front, maybe even closer to Cedar City?
As was mentioned, the top, flares, bumpers and nerf bars were added-on, as well as the wheels were painted black (they were only either white, chrome, or gold - if it was a Golden Eagle). If you have a factory tach and clock in the dash panel, there's a chance it could be a Renegade or Golden Eagle - I don't recall any CJ-5s that had the Laredo package... which could be rare if so. Looks like the previous owner might've had a grille protector installed at one point as well.
I'm pretty sure, I am more excited to get home to see it and take pics. I found it on a Sunday, bought it on a Monday, drove home, then had to pack me and my wife up for a 10 day trip to California for work. I am still 2 hours away lmao. I am just excited.
Nice cj. A couple of cutoff wheels and a bit of grinding to rid yourself of the xtra bars. I did on mine. 5s are hard enough to get in and out of anyway. Good looking old jeep and it looks fairly solid.
Congrats on the new to you CJ! Looks relatively rust free and hopefully will be a fun project. I had to rebody mine it was so rusted out, funny enough the frame was perfect.
Looks like it's been repainted inside and out (original color). The bolts on the dash should be silver. The wheels look period correct but don't seem to be stock. Mentioned above, the stock wheels have a more dimpled cutout. And stock wheels will have a manufacture date stamped on the inside.
Regardless excited for you to get it running and cruise it around. If you want to go crazy with it - I'm running Holley EFI and Hyperspark ignition and highly recommend the upgrade.
I am going to go through these this afternoon and make sure. The only leak I see is a little seepage on the rear end, as it is wet. The drain plug from the oil pan is dripping. I will change the oil and check all fluids today. The only noise I hear, is the throw out bearing is a little noisy, the clutch is strong.
Good morning. My plan is to check fluids in all areas this weekend, check the play in the pedal, check brakes, and just do a full go through before I start driving it. Took it out yesterday, and it did amazing. I appreciate all your advise, and look forward to hopefully picking your brain more,,and using this foundation to make it beautiful.
Those plugs don't look horrible. The ash deposits could indicate your engine is burning a little oil, or a PO might have been using additives in the fuel. I don't see anything that would give me much concern.
Check your new plugs after a few hundred miles. This is what they should look like.
I realized after a little research on my part as I am still remembering all the things about old vehicles. I put in a fuel cleaner as the carb has having a few issues, so that was me. I ran some ethanol free gas through it, and now it seems to be way better. Spark plugs look just like that. Had my father in law come over, and he said that the new ones look amazing and carb is right on now. Thank you for your help.
But that’s the easiest way to find the “ iffy” ones!😂
Related Threads
Jeep Enthusiast Forums
posts
19M
members
766K
Since
2000
