in
this forum
in
the entire site
Advanced Search
Cancel
Create thread
New
Forums
More
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
Menu
Log in
Sign up
Home
Forums
Models
Jeep Wrangler Forums
YJ Wrangler Technical Forum
1.1K online
Unfollow Forum
Follow Forum
Create thread
Filters
Show:
Loading…
1
1 of 4307
Go to page
Go
4307
Sticky
What did you do to your YJ today?
Questor
Nov 28, 2005
4435
4436
4437
89K
6.6M
3d ago
by
fishadventure
Sticky
YJ Chat and non tech
NIUPonyBoy
Jul 12, 2007
1696
1697
1698
34K
1.6M
6d ago
by
Joe Dillard
Sticky
There is no easy way to say this
Luuca
Jun 15, 2015
9
10
11
215
102K
Jun 21, 2025
by
NHfireLJ
Sticky
YJOTM Archive - February 2022 Winner - grandboost98
jbolty
Jun 5, 2012
Locked
11
55K
Jan 20, 2021
by
jbolty
Sticky
*** 8.8 Consolidation thread ***
jbolty
May 15, 2014
2
28
58K
Mar 10, 2019
by
bruinjeeper
Sticky
4x4Trax Fabrication Projects
jbolty
Apr 26, 2015
Locked
6
27K
Apr 23, 2016
by
jbolty
Sticky
** Rules and guidelines for the YJ Section **
NaeKid
Jul 22, 2002
Locked
1
42K
Jan 14, 2014
by
Anticanman
Sticky
â–ş YJ Frequently Asked Questions (FAQ), Write Ups & stock specs. Look here first
rustywrangler
Jul 10, 2008
Locked
14
427K
Oct 7, 2010
by
rustywrangler
Any advice for the Rubicon?
ajhyost
Jun 16, 2025
1 reading
2
52
1.7K
5h ago
by
ajhyost
7120 Intake Port Model
gehlsurf
1d ago
5
88
7h ago
by
gehlsurf
D
92 Yj won't kick into accessory mode
Dustinrama
3d ago
3
131
17h ago
by
fishadventure
89 YJ Weber 32/36 Carb spewing fuel
Caligeaux
Jul 26, 2025
8
311
1d ago
by
fishadventure
95 4.0 stuck in 2nd gear.
ronrymanr
3d ago
1
89
1d ago
by
fishadventure
Battery drain/Battery disconnect options
Waternut
Dec 6, 2023
1 reading
2
75
7.1K
3d ago
by
fishadventure
2
YJ Brake Bleeding HELP!!!
2005-TJ
Jul 10, 2025
24
638
3d ago
by
fishadventure
G
Putting a Hardtop on a soft top 1992 YJ need some wiring help
gbaker53
Aug 4, 2025
7
334
3d ago
by
fishadventure
A
Engine bogs down at around 2k rpm, where to begin
amcmullen
Jul 7, 2025
49
983
4d ago
by
Defend_Dingo
89 YJ no start after backwards jump mishap
chuck Blue
Aug 11, 2025
11
333
5d ago
by
Digger84
D
Vacuum leak at fuel injector
Drossman
Jun 20, 2025
17
508
6d ago
by
Drossman
B
Gauge circuit ribbon…cut off ?!?!
blakelock
Aug 10, 2025
3
153
Aug 11, 2025
by
gehlsurf
K
92 wrangler crank no start
Kipp
Jun 22, 2025
1 reading
2
55
1.1K
Aug 11, 2025
by
fishadventure
Brake system issue 1993 jeep YJ sport
Yahya Ali
Feb 3, 2025
14
697
Aug 10, 2025
by
jbolty
D
Air Conditioner problems
dbarger1$
Aug 4, 2025
7
282
Aug 10, 2025
by
Digger84
Ibooster brake upgrade
gehlsurf
Jul 22, 2025
7
223
Aug 9, 2025
by
gehlsurf
Messed up yesterday :(
jamesmc
Aug 2, 2025
7
262
Aug 8, 2025
by
whoaru99
Tried virtually everything! YJ firing problems
tobes56
Aug 4, 2025
8
204
Aug 8, 2025
by
Defend_Dingo
MCU harness/ mcu/icu and emissions 87 YJ
Judy 87YJ Buda
Aug 3, 2025
3
173
Aug 8, 2025
by
fishadventure
G
Hardtop Alignment
gbaker53
Aug 7, 2025
4
200
Aug 8, 2025
by
gbaker53
Is it recommended to run a fan shroud with a electric fan for YJ jeep?
Fancy89
Jul 30, 2024
65
3.6K
Aug 7, 2025
by
gehlsurf
D
Hardtop Rear Glass Struts (Broken Bolts)
disarm6565
Mar 26, 2025
4
372
Aug 7, 2025
by
gbaker53
The Right Oil Filter?
mikeEstep1
Aug 4, 2025
5
254
Aug 7, 2025
by
mikeEstep1
Lights Jeep YJ Renegade
Chuisin
Aug 5, 2025
2
141
Aug 5, 2025
by
Chuisin
R
Chevy distributor?
red87
Aug 5, 2025
2
118
Aug 5, 2025
by
red87
2
Dana 35 Axle Shafts
2005-TJ
Jul 25, 2025
8
311
Aug 5, 2025
by
OGA
R
Steering Wheel Lost Ground Horn No Honk!!!
RDavi
Aug 12, 2012
20
22K
Aug 4, 2025
by
Hieneken49
"All of the sudden", so rich it won't run? (2.5L Renix TBI)
cas6969
Jul 5, 2024
4
5
6
206
6.5K
Aug 2, 2025
by
cas6969
Changing Belt, 95 YJ 2.5l
shookwell
Apr 16, 2004
11
12K
Aug 1, 2025
by
Kay Stewart
S
Factory Fog/Off-road light replacement
Sahara89_5k
Jul 30, 2025
2
210
Aug 1, 2025
by
fishadventure
Vaccum 4x4 switch leaking??
ab1989
Jul 29, 2025
9
303
Jul 31, 2025
by
jamesmc
Tank Hose Spaghetti
mikeEstep1
Jul 24, 2025
1 reading
8
334
Jul 31, 2025
by
fishadventure
T
No power to fuel pump
Tony penland
Jul 15, 2025
2
27
487
Jul 30, 2025
by
fishadventure
R
Crank no start
RDB533
Jul 26, 2025
6
203
Jul 30, 2025
by
fishadventure
Weber 32/36 Install Write-up
ElvisV04290
Mar 2, 2007
1 reading
6
7
8
260
172K
Jul 28, 2025
by
jeepsandy
1
1 of 4307
Go to page
Go
4307
posts
1.7M
views
332M
Second generation of the classic Jeep - manufactured from 1987 till 1995. Known by their square headlights.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
jbolty
Administrator
Joe Dillard
Top Contributors this Month
View All
fishadventure
D
Digger84
Defend_Dingo
Recommended Communities
Jeep Wrangler Forum
520K members
The Jeep Recon
240 members
Jeep Wagoneer Forum
5K members
Home
Forums
Models
