Hello everyone and thank you for checking out this thread! I'm new here and to car repair in general, so don't beat me up too bad (yet)
I put in as much info on my jeep as I know. Unfortunately alot I wasn't sure about but if you need an answer on anything thats missing, I'll find out.
The problem I'm having is the jeep feels unstable at speeds over 30 mph. I took it on the freeway ONCE and feared for my life. I never gripped a steering wheel so tight at 60mph trying to keep it straight.
My end goal is to be able to take this on a 200 mile trip up north in May (Michigan). Right now I'm afraid to go to the gas station because it won't stay straight.
The guy in this thread has similar issues, but I don't have vibration (that I remember) and I don't have a lift kit. http://www.jeepforum.com/forum/f12/cant-keep-her-straight-268064/
It feels like you have to "catch" the jeep as it sways back and forth. Any bump in the road is a religious experience. I just bounce between the lines while I'm doing 35-40 mph. I really don't dare to go faster because it really feels out of control.
So far I've been able to glean the following information from other threads / questions people have asked:
- Lugs are tight on all wheels.
- No lift kit, stock suspension AFAIK.
- Power steering box has been tightened, possibly too much because the wheel is slow to straighten itself out when its been turned.
Possible problems:
-Steering dampener (this might be missing, i didn't see anything with a spring under there)
-Ball joints
-Wheel bearings
-Sway bar
-Trackbar
-Drag link
-Tie rod
Possible solutions:
-Replace power steering box.
-Replace steering shaft (done)
-Balance tires (has not been done)
-Align tires (also has not been done)
Repairs made to date (Most I'm pretty sure are unrelated):
-Replaced steering shaft and that took some play out of it, but it still feels unstable at anything over 30mph.
-Tightened power steering box
-Replaced exhaust from the manifold to tailpipe (everything except the manifold)
-Replaced serpentine belt
-Replaced oil pickup
-Replaced oil pan
-Replaced battery
-Replaced stereo
-Replaced internal door handle
-Removed rear seat
My biggest question is, where should I start? Next question, what order should I attack these things?
Thank you for reading and for any advice you have to offer.
Possible problems:
-Ball joints
-Wheel bearings
-Sway bar
-Trackbar
-Drag link
-Tie rod
Possible solutions:
-Replaced oil pan
-Replaced battery
-Replaced stereo
-Removed rear seat
