I have a 2001 Jeep Grand Cherokee Limited V8 with weak passenger side air. The driver's side blows pretty well, but there is HUGE difference in air which can even be felt coming out the drivers and passengers vents which are both right next to each other in the center of the dash by the radio. The drivers side blows OK but isn't as cold as I feel it should be and all the passenger side vents only blow about 10% as hard as the driver's side, maybe less.
It has been around 100 degrees here everyday for the past month and the whole system is no longer keeping up with the Texas heat, even on the driver's side. It is making me not want to drive this vehicle anymore even though the rest of it is mechanically sound.
I am very mechanically inclined and do almost all work on this vehicle myself, but I brought the vehicle to an A/C mechanic because I do not feel comfortable with trying to recover the R134a without releasing it into the air and the A/C is the one thing in the car I try not to touch. Unfortunately, he didn't fix the problem although he did find a leak at my compressor and replaced it.
When doing the Climate Control fault codes by holding the A/C and Recirculation buttons and moving the drivers side temp dial 1 click, I get the following codes:
42 "One of four motor drivers had drive 9A9 shorted to ground"
52 "AI (Recirc) door travel range too large"
54 "Left temperature door travel too large"
56 "Right temperature door travel too large"
Trouble with this is, about 2 years ago I completely took apart the dash using the guide on wjjeeps.com and replaced the Recirculation door and the blend doors myself. The parts I replaced came with the doors and the "housing" that the doors connect to, not just the doors.
Any idea on what could be causing the issue with my HVAC not blowing hard/cold enough and almost nothing on the passenger side?
