Hoping this helps someone down the road, as this leak above the pump seems to be a common issue.
I recently replaced my power steering pressure hose on my JGC 4.7 HO, it's simple and not simple at the same time.
You will need a 13/16 wrench and LOTS of PB blaster. And if you're like me, a hammer might not be a bad idea either.
I started by sucking all the fluid out of the pump with a turkey baster, then popping off the bolt covers on each end of the hose. Then unscrewed the top bolt (the connector to the pump) and immediately found the problem. The o-ring that sits in between was pretty much not existant. In my case, I already had the replacement hose so I went ahead and installed it anyways. But if you have this problem, you COULD probably get away with replacing the o ring. If you decide to replace the hose, you will need to have a keen eye and a tight grip, lining the hose up with the hole under the car is a pain in the behind. Once you get that it, don't forget to relatch the plastic clip and refill your resovoir.
This project costed me about 65 dollars and 2 hours of work time, which isn't bad considering I was losing almost half a tank of power steering fluid every 4 days!
