have noisy lifters, can anyone help out with causes, solutions? Are there any additives I can use? Right now I'm running royal purple 5W-30, should I switch to a thicker oil?
so much for my user manual!5w probably wont hurt but these engines are designed for 10w at the thinnest.
you might want to read up on oil, the first number, the 10W doesn't mean its a lighter oil. the second number, the 30 or 40 is how thick the actual oil is and is the only one that acually matters, the W number just says how low the temperature can go before the oil thickness starts to change, ideally you want a 0W number. Maybe I'm mixing something up, but you can read up about it at www.bobistheoilguy.com.hi all
you are running too light an oil, you should run 10w-30w, unless the sticker under hood recommends somethings else. 5w probably wont hurt but these engines are designed for 10w at the thinnest.
earmuffshave noisy lifters, can anyone help out with causes, solutions? Are there any additives I can use? Right now I'm running royal purple 5W-30, should I switch to a thicker oil?
7 Quarts???? Isn't that 1 quart over filled?I'm running 7qts VR1 20/50 with a Motorcraft FL1A filter. When I picked this jeep up a couple of months ago it ticked loud as all get out, and the dealer had just changed the oil. As soon as I cranked it with the VR1, it was dead silent. Between that and tightening up my exhaust collector bolts, my rig doesn't even sound like a jeep anymore.
Or just get over it and go on with life, if that doesn't work sell your Jeep and buy a Camry, you don't deserve it if you can't handle all it's quirks. I'll pay you 2,500 for it.you could always try one of the aluminum valve covers from quadratec...cost about $100 but they look ok and im sure its thicker material there for more insulation from the valvetrain noise.
The W number isn't how low the temperature can go before the oil thickness starts to change. The two numbers are viscosity ratings at two different temperatures. The W means it is the viscosity rating at 0 degrees fahrenheit. The second number (if I remember correctly) is the viscosity at 212 degrees fahrenheit.you might want to read up on oil, the first number, the 10W doesn't mean its a lighter oil. the second number, the 30 or 40 is how thick the actual oil is and is the only one that acually matters, the W number just says how low the temperature can go before the oil thickness starts to change, ideally you want a 0W number. Maybe I'm mixing something up, but you can read up about it at www.bobistheoilguy.com.
Correct, obviously the lower number the better it will flow but with less volume as well, it's not cut and dry as to which grade of oil to use and varies by engine but for the 4.0 5W-30 to 15W-40 will all work just fine, the 4.0 isn't really picky about the grade of oil just as long as there's 6qts in there and it has some sort of ZDDP.The W number isn't how low the temperature can go before the oil thickness starts to change. The two numbers are viscosity ratings at two different temperatures. The W means it is the viscosity rating at 0 degrees fahrenheit. The second number (if I remember correctly) is the viscosity at 212 degrees fahrenheit.
Yeah, in my high performance engine design class (note: it was mainly geared towards drag racing), we were always told to run the thinnest oil possible without oil contamination and metal-to-metal contact.Correct, obviously the lower number the better it will flow but with less volume as well, it's not cut and dry as to which grade of oil to use and varies by engine but for the 4.0 5W-30 to 15W-40 will all work just fine, the 4.0 isn't really picky about the grade of oil just as long as there's 6qts in there and it has some sort of ZDDP.
No, it's thicker because it's cast aluminum and not stamped sheet metal. Also, more/thicker material doesn't always directly equate into more sound insulation. Sonic properties don't work that way.you could always try one of the aluminum valve covers from quadratec...cost about $100 but they look ok and im sure its thicker material there for more insulation from the valvetrain noise.
