Ultimate OEM spring rates and codes chart
22K views 10 replies 5 participants last post by  dave95_xj
Cross posted from another forum I frequent, this is my attempt to document the various coils used in the XJ/MJ/ZJ jeeps. This should make is far easier to identify the correct junkyard parts, or to mix and match the coils on your rig to account for extra weight, etc.
This info has been pieced together from a dozen different sources.... Please post below if you have any fill-in-the-blanks for me, and I will update accordingly.
"Chrysler makes a variety of springs for the GC. There are two main types, base and HD, and in each type category there are 5-10 different springs with different GVWR (Gross Vehicle Weight Rating) capabilities. The springs are denoted by a two digit code as well as a part number."
vehicle build code SDA = normal duty
vehicle build code SDB = heavy duty
V and U spring codes are for right side (passenger), G and F are for left side (driver)
Image version:
text version, spaces not lined up:
Model Code P/N Spring Rate Suspension Trim Engine
XJ UD,FD FD 52001113 #570 SDA
XJ UE,FE FE 52001114 #607 SDA
XJ UF,FF FF 52001115 #646 SDA
XJ UG,FG FG 52001116 #688 SDA
XJ UH,FH FH 52001117 #733 SDA
XJ UJ,FJ FJ 52001118 #780 SDA
XJ UK,FK FK 52001119 #831 SDA
XJ VD,GD GD 52001120 #578 SDB
XJ VE,GE GE 52001121 #670 SDB
XJ VF,GF GF 52001122 #622 SDB
XJ VG,GG GG 52001123 #720 SDB
XJ VH,GH GH 52001124 #775 SDB
XJ VJ,GJ GJ 52001125 #834 SDB
XJ VK,GK GK 52001793 SDB W/ UC 4.0
XJ VL,GL GL 52001794 SDB
ZJ UJ,FJ FJ 52088102 SDA
ZJ UK,FK FK 52088103 SDA
ZJ VK,GK GK 52088104 SDB
ZJ VL,GL GL 52088105 SDB W/ UC 4.0
ZJ UL,FL FL 52088181 SDA 4.0
ZJ UN,FN FN 52088362 SDA 5.2
ZJ VN,GN GN 52088363 SDB W/ UC 5.2
ZJ VP,GP GP 52089141 SDB W/ UC
ZJ UM,FM FM 52088361 SDA
ZJ SL,DL DL 52089171 SDA
I have found that any spring with the first letter code G ( in column C ) is an Up-Country (UC) spring and is 1" taller than a stock
spring with a first letter code F. This applies to both XJ and ZJ.
I have found that any spring with the first letter code G ( in column C ) is an Up-Country (UC) spring and is 1" taller than a stock spring with a first letter code F. This applies to both XJ and ZJ.
As you can see from the XJ list, even G codes had different rates. The rates varried based on vehicle build and options. For instance, a 2.5 2wd will have different rates than a 2.5 4wd will have different rates than a 2.5 4wd with the skid plate package etc.
Not all G codes are upcountry. Rather, G-code is the "heavy duty" versus "standard duty"; and does not necessarily denote UpCountry.
Well that is bad news for me considering i got some FN coils the other day from the junk yard... i saw it on rock lizard lifts and he didnt specify the part number just that he got 2.25 inches of lift... would u guys say he was lying?
There are so many different ZJ coils that no-one has ever charted the results of installing each one in a stock Cherokee.
Coil springs spacers are about $35 a pair and provide an exact amount of lift. This would be a better choice than wandering around a junkyard, pulling some unidentified ZJ coils and installing them in your Cherokee, only to find you get little to no lift.
Ya i understand. But wouldn't full coils be better than spacers? I know i know im pretty stupid i suppose. I am also making a bastard pack i just want to do it myself. The screwy part is going to be what shocks to buy lol. Anyways thanks bro i got the damn coils so ill toss them in. If i get no lift ill get the spacers =/
Aah that is the best thing i have ever heard. 3inch coils only 100$ damn. i think i just fell in love. Now lets see if i can still put my extra xj leaf pack to use i bought maybe use the main and second that may net me 3 inches to the rear. But ill just toss the main with eyes cut off and these damn zj coils in for now. dont want a 3 incher lift with these crappy 235/75 tires on here so ill order the rustys and wait for my tires to install the extra second leaf and the 3inch coils...
Just got offered a promotion at work pays an extra 2.25$ an hour so what the hell. ill go with a 3 inch lift. i have been so well decided on a 2 inch lift but why not 3?? Then i can grab some 31 inch all terrains maybe a case drop with longer break lines and of course some shocks and be rollin till the end of the jeeps days
