Springs heights and their spring rates? - JeepForum.com
post #1 of 82 Old 10-02-2008, 01:32 PM Thread Starter
gunselman
So i have been looking into spring rates and heights. There doesn't seem to be a centralized location for this information. I feel this can help people get the ride and height that they are looking for.
Any information on spring heights and rates is appreciated.
Current info:
Coil Springs:
BDS 3" XJ coil 240lbs/inch
Rough Country 9269, 4.5" 170lbs/in
Rough Country 9275, 6.5" 190lbs/in
Zone Offroad 4" XJ coil 240 lbs/inch
Full -Traction 3.5" 175 lbs/inch
Iron Rock Offroad 4.5" XJ coil 230 lbs/inch
RE1300 3.5" XJ coil 240 lbs/inch
RE1310 4.5" XJ coil 164 lbs/inch
RE1345 5.5" XJ coil 184 lbs/inch (4.5" on ZJ)
RE1358 7.5" XJ coil 213 lb/inch
Rustys 3" XJ standard coil 150 lbs/inch
Rustys 3" XJ Heavy Duty coil 180 lbs/inch
Rustsy 4.5" XJ coil 150 lbs/inch
Rustsy 6.5" XJ coil 150 lbs/inch
Rustys 9" XJ coil 180 lbs/inch
OME 930 XJ coil 160 lbs/inch ~2"
OME 934 ZJ coil 180 lbs/inch
Old Man Emu coil springs (A)= Driver side (B)= Passenger side
DPGXJ5 DPG Trailgunner 5" coils = 198lbs/in.
Rockkrawler 6.5" are 165 lbs/in
Rock Krawler 5.5'' coils: Front: 200 lbs/inch Rear: 235 lbs/inch
Rock Krawler 4.0'' coils: Front: 190 lbs/inch Rear: 225 lbs/inch
Teraflex 5" coils: Front: 240 lbs/inch Rear: 240 lbs/inch
Teraflex 4'' coils: Front: 200 lbs/inch Rear: 210 lbs/inch
Teraflex 3'' coils: Front: 170 lbs/inch Rear: 190 lbs/inch
Rancho 3" coils, at least the old coils give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate.
Sky Jacker 3" ZJ coils 218 lbs/in ~4" on a XJ
OEM is supposedly 147 lb/in rate.
OEM ZJ with 4.0 is supposedly 190 lb/in rate front and rear.
Tera 4" TJ coils give 4.5" of lift on an XJ and have a 200 lb/in rate , 20.25" tall unloaded
Tera 3" TJ coils give 3.5" of lift on an XJ and have a 170 lb/in rate
Leaf Springs:
OLD MAN EMU-CS034RA (OMEJC1A) 5 leaves in pack, 148lbs/inch s.r. 230mm (9.055") free height= Average lift of ~3"
OLD MAN EMU-CS034RB (OMEJC1B) 5 leaves in pack, 148lbs/inch s.r. 205mm (8.07") free height
OLD MAN EMU-CS035RA (OMEJC2A) 4 + 1 overload, 137/257lbs/in s.r. 235mm (9.25") free height
OLD MAN EMU-CS035RB (OMEJC2B) 4 + 1 overload, 137/257lbs/in s.r. 210mm (8.27") free height
OLD MAN EMU- D22XL (OME Add A Leaf) ~ 1" lift on top of their lift packs
Old Man Emu springs (+) = driver side (-)= passenger side
RE1463 3.5" (6 leaf) = 190lbs/in
RE1462 4.5" (6 leaf) = 190lbs/in
DPG Off Road -XJ35-0 DPG TrailGunner 5" Leafs (7 leaf) = 233lbs/in
Full-Traction 3.5" 200 lbs/inch
Skyjacker 2.5" leafs P/N: JC25R - 140 lbs/inch up to the overload spring
Thanks to all that have helped so far!
gunselman is offline
post #2 of 82 Old 10-02-2008, 07:26 PM Thread Starter
gunselman
no one has any tech on this?
post #3 of 82 Old 10-03-2008, 08:37 AM
gorman
gorman's Avatar
I've documented some info before, but it hasn't been verified so I'm not too sure about the accuracy.
RE 3.5" 250lb/in (similar to yours)
RE 4.5" 169lb/in
RE 5.5" 185lb/in
OME 930 (XJ) 160lb/in
OME 934 (ZJ) 180lb/in
2000 Cherokee Country 4.0l, AW4 auto, NP242, RE/OME 6" lift, OME N35L & N36 shocks on raised mounts, JKS Quicker Disconnects, RE SYE, RE CV driveshaft, 33" Maxxis Bighorns, Cragar D window 15x8 with 4" backspacing, ARB bumper, Hella Comet 550's, Warn M8000 winch, GME GX300 29mhz, custom rocksliders, Gearmax Mod 89 rear axle, HP D30 front axle with WJ knuckles, steering and brakes, 4.56 ratios
gorman is offline
post #4 of 82 Old 10-03-2008, 08:53 AM Thread Starter
gunselman
RE 4.5" 169lb/in
RE 5.5" 185lb/in
I will add it to the list. I just called RE about the 3.5" coils this week so i will keep the 241 lbs/in. Thanks for the rest.
post #5 of 82 Old 10-03-2008, 09:48 AM
gorman
gorman's Avatar
Just as a matter of interest, I've had three of the ones l list fitted in my Jeep before. It started out with the OME 930 (supposed to be a 2" lift, but it's a little less), I then had the OME 934s in to help cope with the extra weight of an ARB bumper and winch and then settled for the RE 4.5" with a spacer to nett me just over 5" with the bumper and winch. Ride wise I can't tell the difference between them, even though the spring rates differ.
gorman is offline
post #6 of 82 Old 10-05-2008, 07:25 PM Thread Starter
gunselman
Thanks for the info.
post #7 of 82 Old 10-05-2008, 09:56 PM
jebmccall
1997 XJ Cherokee
shoot the rustys are supposed to be some of the softest, but they seem to ride really really rough.
jebmccall is offline
post #8 of 82 Old 10-06-2008, 06:30 AM
lcarney91
Here are the specs on the OME rear springs:
CS034RA (OMEJC1A) 5 leaves in pack, 148lbs/inch s.r. 230mm free height
CS034RB (OMEJC1B) 5 leaves in pack, 148lbs/inch s.r. 205mm free height
CS035RA (OMEJC2A) 4 + 1 overload, 137/257lbs/in s.r. 235mm free height
CS035RB (OMEJC2B) 4 + 1 overload, 137/257lbs/in s.r. 210mm free height
This info came straight from an email request from their customer service...... should be accurate. Hope this helps
1999 XJ.....
Stock, with some intake/exhaust work
"The ol' family truckster"
lcarney91 is offline
post #9 of 82 Old 10-06-2008, 09:09 AM Thread Starter
gunselman
Added it to the list. Thanks!
post #10 of 82 Old 10-09-2008, 01:19 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Some info to add.
According to RE, the spring rate for both their RE1463 3.5" and RE1462 4.5" XJ leaf spring packs is 190lbs/in.
For the DPG Offroad TrailGunner springs:
DPGXJ35-0 DPG TrailGunner 5" Leafs (7 leaf) = 233lbs/in
Unfortunately I don't have free height measurements for any of the springs (didn't occur to me at the time to measure them when I had a set of RE springs and DPG springs together). The RE springs have 6 leafs, the DPG springs have 7.
FWIW, here's the RE1463 3.5" leaf spring compared to the 5" DPG leaf spring. Despite being rated at different heights, they'll net the same amount of lift to probably within 1/2" of eachother.
DPG spring on top, RE spring bottom.
DPG spring in back, RE in front.
edit: Also, here is the RE 5.5" coil vs the DPG 5" coil. RE coil is grey. The DPG 5" coils will yield ~1" less height than the RE 5.5" coils.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #11 of 82 Old 10-09-2008, 01:35 PM Thread Starter
gunselman
Thanks Jason!
post #12 of 82 Old 01-06-2009, 05:28 AM
michel1972
1993 XJ Cherokee
Hello,
I know this topic is what older but here in Europe we have tested the Rusty
9" XJ Coils and i can tell you they were not the 180 lbs/inch what they say.
We have tested last month 2 different 9" coil springs here in europe on 2 different machines and they gave a complete different spring rate as what Rusty is telling. Here are the figures for the 9" coil spring.
The spring rate for these 2 coil springs were between the 241.18 and 251.85 lbs / inch
So they are harder as they tell you and these measurements are very precise.
Greetings
Current info:
Coil Springs:
michel1972 is offline
post #13 of 82 Old 01-06-2009, 06:01 AM
dcorn
It's the shocks that ride rough. Once I put OME shocks on Rusty's regular springs, my front end was suuuuper soft. Couple that with a heavy bumper and I was bottoming out all the time.
Judging by the lengths and rates, I should have gone with a DPG 5" spring on my RE 4.5" lift and Rigid bumper to level it out with the rear. I'd rather do that than add a spacer, but I gotta go cost effective right now.
This is great tech info guys, thanks to everyone for posting up.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #14 of 82 Old 01-13-2009, 07:07 AM Thread Starter
gunselman
does anyone know why RE 's coils are so different over their heights? I would think that the higher you get the more spring rate you will need to keep said amount of lift. It seems by their numbers it is just the opposite.
3.5" = 241
4.5" = 169
5.5" = 185
Any thoughts?
post #15 of 82 Old 01-13-2009, 07:16 AM
gorman
gorman's Avatar
My guess would be that it's like that to match the rear leafs. The 3.5" lift as an example uses a spring pack that mounts onto the original shackle which would thus give a bit of a stiffer ride. The 4.5" lift uses the same leaf pack but with longer shackles to thus it give the rear leaf a bit more room to move and possibly a softer ride. The 5.5" lift likely uses a spring pack that's a little stiffer of with more curve and a replacement shackle and that is why their coils have slightly higher spring rate to the 4.5" lift coils?
This is purely a guess.
gorman is offline
spring rates Apestit XJ Cherokee Technical Forum 8 06-30-2012 02:53 PM
Factory spring rates for front springs Super73 XJ Cherokee Technical Forum 4 10-27-2009 11:30 PM
leaf spring rates.... lcarney91 XJ Cherokee Technical Forum 3 11-15-2007 07:12 AM
XJ Spring Rates Kiwi_TJ XJ Cherokee Technical Forum 3 11-13-2006 07:41 AM
Spring rates. VR6NH XJ Cherokee Technical Forum 1 11-10-2005 05:21 PM
