TJ Heat Not Truly Hot???
Hi Guys, Just to say a good word, I know that this thread is a little old but I I myself was experiencing the same issue on my 97 Sahara. I began with isolating the heater core, buying a Prestone Flush Kit, using the garden hose. After flushing a few times and seeing some dirty mix, I decide to make a very diluted mix of warm water and CLR (I mean Weak), allowing the mix to set for about ten minutes I flushed the heater core through the hoses, both ways, through inlet and outlet, for about fifteen minutes to attempt to remove all the CLR. Okay, so after completing this I did have an improvement with the heat going from luke warm to warm. I wanted true heat, as my '93 YJ will toast you out, I knew the TJ wasn't completely working to its capabilities. Soo..I decided to flush the entire cooling system, since I had bought this TJ a few months ago, I had no clue on how often the system had been maintained. I went with Zerex (G-05) and Distilled Water. After draining and flushing about five times (1 hr), I did so trying to get all old coolant out, since it was Orange (Dexcool or forbid Original) I did not want to mix the two. Once the coolant ran clear the last two drains, I completely emptied one last time. Now since I had it all apart I decided to change the thermostat, since it was taking forever to warm up and compared to YJ, not where it should have been. So after changing thermostat, replacing with correct coolant, I went from warm heat to hot heat. Following day, after experiencing passenger floor water, I ended up pulling the blower motor out to seal up with RTV sealant, and this is the kicker. I simply could not believe the gunk built up against the heater core from assuming the cowl drain leaking after being clogged (cleaned out weeks prior). After cleaning out the gunk against the heater core, shop vac and fingers, I reassembled blower motor. With winter coming up, I am assured I have heat, believe me, little efforts (time and about $40 bucks) I have a new thermostat, fresh coolant, clean cowl drain, sealed blower motor and A/C drain, and most importantly, no water leaks and lava heat. Sorry for the length, just wanted to share all attempts and what showed best results, in the end all efforts minimal made great strides for what I was wanting and expecting.
