My 03 Liberty that all the sudden started making a loud ticking/tapping metallic noise from the passenger side of the engine and has a very rough idle to the point of shaking the whole car. The ticking increases with RPM.
I did an oil change and put in new spark plugs. While the plugs were out I did a compression test and all the cylinders were about the same at little over 180psi.
When removing the old plugs, the number 2 plug (passenger side front) was a little cleaner then the others and was wet with gasoline. I swapped the coil for one on the other side and there was no change. I checked the coil and it was producing a spark.
I took a piece of hose and listened around and the ticking seems to be coming from around where the the number 2 cylinder head and valve cover meet.
So now I am not sure where to go. Could a stuck open injector cause that loud of a ticking and rough idle? Or is it more likely a valve problem?
Thanks for any help,
Matt
Matt
