1) have Willy’s with two axels but rear is bad, do I replace axel and upgrade brakes or swap for later model with disc brakes and cut the chassis to fit
2) want to use a supercharged V6 and S10/ Blazer 4x4 automatic transmission , transfer and maybe chassis and power steering which will apparently match up to V6 if it has split bell housing
3) as another alternative I located a later model Grand Cherokee 4.0L transmission and transfer case with OD
4) Since I have OD in either transmission I can use Dana 44 or Ford 8.8 rear
Your opionions?
Your opionions?
