I have my new engine on a stand and I need to remove the crank pulley because I want to give the block a nice coat of paint. All you have to do is take the bolt out and use a harmonic balancer puller to take the pulley off, correct? Since the engine is out of the jeep, whats the best way to immobilize the flywheel/crank so I can get the bolt out? When I reinstall the pulley, I just need to make sure I have the notch lined up with the correct place on the timing cover correct?
