Rear clunking noise solved..finally
6.3K views 3 replies 3 participants last post by  jdk3034
I finally found a loud clunking noise in the Jeep. It has been driving me crazy for three months. It turns out that it was one of the lower rear shock bolts. I had to break the bolt to get it off. Since it is a ½” OD bolt I used a breaker bar and ½”-drive sockets. Once off, I could see that the outer diameter of the bolt had worn down to a much smaller size. When I would hit a bump, the shock would travel in the slop first, before compressing and doing it’s normal job. This created a clunk clunk clunk. I cannot explain why the bolt wore so badly. The shock only partially rotates around this bolt by a couple of degrees. Maybe rust and dirt get in there?
yea...real hillbilly setup on the stock set-up. I got them on good & tight with some of my own tricks. It aint going nowhere now.
The stock bolts are 12mm tapered...don't ask me why they are tapered. :confused:
Had the same thing happen. Pressed some new 5/8" hourglass poly bushings in the shock hoops. Then pressed in some 1/2" ID bushing sleeves out of a Rancho install kit. Then finished up with 1/2" grade 8 bolts. Haven't heard anything from the rear suspension for years.
Link to bushings 9.8107
http://www.energysuspension.com/pages/sk_bsp1.html
