Sounds good. Thanks for the heads up.
Sounds good. Thanks for the heads up.Stay away from radiatorbarn.com... IMO
I heard the all metal or all aluminum radiators have issues like these. What did you replace the radiator with? Stock?? Do you have any other issues like CEL's, running rough, high idle, and is there anything in your AC fins?So I bought my jeep used (1997 4.0).... the rad has been replaced by the last owner all metal not the stock metal and plastic.... If I go for a longer drive on the highway the temp will start to creep up to the red after 30 minutes or so.
Thanks for the info.The cooling system is a group of related parts that depend on proper function from each of its component parts to keep the engine cool. Service the cooling system and replace any under-performing or suspected weak parts. This is normal routine maintenance that should be done on all vehicles. Any component part of the cooling system that is not fully doing its job will stress the others and your cooling system will overheat. The most important maintenance item is to flush and refill the coolant periodically. Anti-freeze has a number of additives that are designed to prevent corrosion in the cooling system, but they have a limited life span. The corrosion causes scale that eventually builds up and begins to clog the thin flat tubes in the radiator and heater core, causing the engine to eventually overheat. Coolant should be replaced every 36,000 miles or every three years.
