2006 4.0L with manual NSG370. To make a long story short, my current Jeep is having a long crank time and idling and rough running issue that I am struggling to figure out. I am in Florida for the winter without my garage or tools and heading back to NJ in two weeks and hoping too get it corrected before I leave. The engine did have slop in the timing chain while I had it out and I replaced it with Cloyes unit set to TDC and it took all the slop out. New Crown OPDA that I have used the OEM and Enclin cam sensors with identical results. I used the Thinkdiag2 to adjust the cam/crank sync multiple times and done the relearn procedure. The sync starts as "out of sync" and changes to "in sync" after the long crank time and it starts. I am assuming that it should start out as in sync but I have nothing to compare to at the moment. Has anyone used the TD2 that has done the procedure and knows? If it is an issue anyone how to remedy it? It also idles rough and sometimes hesitates and shudders while at cruising speeds. Sounds like it might die but never has. It accelerates fine and seems to do fine at highway speeds. There are no CEL codes present. I tested the fuel pump pressure its steady at 59 PSI, drops to about 55 after an hour and jumps right to 60 with key turned. Priming the pump a couple times does nothing and I am confident its not a fuel problem. Old injectors worked fine but I changed them out because of visible cracking with new Bosch models with no change at all. I have tried looking at numerous data with the TD2 but everything I checked either seems ok or I dont even kow what a lot of the data even is. Anyone have any ideas what might be going on or other things for me to try? Any other data on the TD2 I should be looking at?
I have added a bunch of new parts some as maintenance, some because I noticed issues like cracked injectors, cracked coil rail, cracked TPS, others I have changed to try and narrow down the issues I am having.
New Crown OPDA
New Mopar crank sensor
New Bosch injectors
New spark plugs
New Hitachi coil
New TPS
One new 02 sensor (CEL code that is now fixed)
The two pictures below are before it starts and after it is running and here is a vide of it cranking.
TIA!
New Crown OPDA
New Bosch injectors
New spark plugs
New Hitachi coil
New TPS
TIA!
