Correct amount of oil, fresh change and filter last weekend. Promlem existed before last change and still continues now. Not overheating nor is the check engine light on. I have a code scanner and checked to make sure that there were no codes as well.
At idle my oil pressure gauge holds around just below the 40 marker. When i accelerate at any speed/rpm the gauge just floats all over the place until i stop again and then it stays at normal idle pressure. I dont see any leaks and I don't have any coolant in my oil. I dont hear any clanking or noises that concern me. I replaced the oil pressure sensor/switch awhile back after a code popped for that, then my jeep ran fine for months before i started having this current issue.
Any suggestions on what to check or replace? I was told possibly the sensor i replaced is faulty again, but i have no code showing and that it could be my gauge itself.
