Need help with viper 5806v remote start install.
4.2K views 11 replies 4 participants last post by  rep-tile
I am having issues trying to figure out how to connect the wires to the ignition switch harness.
I can get it to lock/unlock the doors. My aux outputs are working. I just can't figure out which wires need to be hooked up and to where for the white 10-pin heavy gauge connector
The DBALL2 is programmed already
Thanks in advance
Do you have a wiring diagram? What color wires are in your 10 pin?
If I'm correct it should be:
CAR: Remote start:
red----------------------red/black
pink/black--------------red
Yellow(ign side)------->green
Yellow(car side)------->violet
dk blue-----------------pink (with pink wire from DBALL2)
I'm lost on what to do with the rest of the wires
Edit: I was trying to figure that out before your reply KOZZ. Looks correct. I might try that
IF I found the correct wiring diagram, I think you'll want the following. I'm adding a disclaimer here - I'm only piecing together information and giving you suggestions. I have no way of knowing if this is actually correct so proceed at your own risk.
Red - Jeep Ignition Switch (Red)
Red/White - Jeep Ignition Switch (Red)
Pink - Jeep Ignition Switch (Dark Blue)
Violet - Jeep Ignition Switch (Yellow)
Orange - Jeep Ignition Switch (Red/Black)
Pink/White - Jeep Ignition Switch (Black/Orange)
NC - No Connection
Red/Black - 12V Accessory/Starter Input - ???
Pink/Black - Probably Not Required
Green - Starter Input - ???
https://pdf.ampire.de/viper/QRN5X06 2013-08 web.pdf
http://www.directeddealers.com/manuals/IG/Viper/N5702V_2008_08web.pdf - Page 22
