So I have a 2006 Wrangler (Automatic). For the past few months, I have had issues with it starting intermittently. Initially thought it was the CPS, so I had that replaced and it was fine for a few days before it starting doing it again. I dealt with the intermittent issues for a few weeks until it would crank but never start one day. Just took it in and had a new battery installed and the PCM reset. Old battery was giving out inconsistent readings before, so we figured that it had messed up the PCM. Ran fine for 4 trips the day that I got it back from the shop, but the day after it won't start at all.
When it does start, it runs perfectly fine. There have only been 2 times where it idled hard and shook for a second right after turning it on, but then it idles/runs fine.
Any ideas? I have been thinking either Neutral Safety Switch or bad PCM. Leaning more towards PCM as it won't start even in neutral.
