Selectable Battery/Accessory Power Source - JeepForum.com
post #1 of 15 Old 08-04-2011, 02:13 AM Thread Starter
ronjenx
ronjenx's Avatar
On my 2008 JK, there are two power outlets on the bottom of the center stack.
The left outlet is #1, fuse #M6, wired to Accessory power.
The outlet on the right is #3, fuse #M36, always powered.
I noticed in the TIPM fuse box, there is a fuse #M7, for outlet #2, selectively powered by the battery and accessory circuits.
I also noticed my JK does not have outlet #2, but the 20 amp fuse is in place, in the 2 position socket.
Here is a picture of Fuse M7's location, and a close-up of where to position the fuse for accessory power and battery power.
The center pin socket for M7 goes to pin #12 in the TIPM connector C6, shown in the next picture.
The dealer didn't have a wire with the proper terminal to fit in TIPM wire harness connector C6, so I went to a junk yard, found a late model Jeep, (might have been a Patriot), and pulled a 12 AWG wire, with the correct terminal end. For the 20 amp fuse, I wouldn't use a wire smaller than 16 AWG, to be on the safe side.
Here is a picture of the terminal end. It has to be exactly like this, or it won't work.
Once I got the wire home, it was a matter of about 20 minutes to install it in location #12 of TIPM connector C6 wire harness.
The first thing I did was disconnect the battery negative terminal.
If you want a built in selectable battery/accessory power source, protected by a 20 amp fuse, consider taking advantage of the unused M7 fuse in your TIPM. Don't do this if you are not comfortable raising the TIPM, and unplugging the connector.
ronjenx is offline
post #2 of 15 Old 08-04-2011, 02:37 AM
1222
RIP John
1222's Avatar
Wow, most excellent. Beautiful write-up and pics too, well done as always.
1222 is offline
post #3 of 15 Old 08-04-2011, 08:29 AM
dsjk
2011 JK Wrangler
Great stuff thank you so much for that!
Originally Posted by voodooJK View Post
Something you said after the fact exposed that part of me... like a catholic school girl normally would.
dsjk is offline
post #4 of 15 Old 09-14-2011, 12:18 PM
jjgreen50
Very useful information, thank you.
jjgreen50 is offline
post #5 of 15 Old 12-15-2011, 11:47 AM
MKE_Mike
2016 JK Wrangler
subscribe to be able to come back here!
MKE_Mike is offline
post #6 of 15 Old 12-15-2011, 11:52 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You don't need to subscribe.
This and many other useful threads are listed in the JK F.A.Q.
Jim
JLC08JK is offline
post #7 of 15 Old 05-07-2013, 06:06 AM
dramon
2011 JK Wrangler
Hi,
To which pin hole on C6 connector do I have to connect my DRL's light's cable to use on RUN ignition mode?,
Thanks.
http://imageshack.us/photo/my-images...werpoints.jpg/
dramon is offline
post #8 of 15 Old 05-07-2013, 09:13 AM Thread Starter
ronjenx
ronjenx's Avatar
If your TIPM is like mine...
Here is a thread showing how to do it from the top:
http://www.jeepforum.com/forum/f96/e...10/?highlight=
If you connect from underneath, here is a pic identifying the pins.
ronjenx is offline
post #9 of 15 Old 05-07-2013, 09:39 AM
dramon
2011 JK Wrangler
Thanks for your answer.I have read that thread.I shifted up the TIPM and released the C6,but didn't know where is pin 14,18 and 28.Another problem is I couln't find wire terminal end that fits to this pin slot in Turkey because there were a few jeeps in the junk yard.I need 3-4 wire end terminals,where can I find these and could someone help me?,
Thanks again.
Sorry my bad English.
dramon is offline
post #10 of 15 Old 05-07-2013, 09:52 AM Thread Starter
ronjenx
ronjenx's Avatar
Originally Posted by dramon View Post
Thanks for your answer.I have read that thread.I shifted up the TIPM and released the C6,but didn't know where is pin 14,18 and 28.Another problerm is I couln't find wire terminal end that fits to this pin slot in Turkey because there were a few jeeps in the junk yard.I need 3-4 wire end terminals,where can I find these and could someone send me these to Turkay?
The dealers here do not carry the terminals. That's why the junk yard was the only source.
It looks like your best option is to do this from the top.
You would be using this as a relay trigger, right?
ronjenx is offline
post #11 of 15 Old 05-07-2013, 10:54 AM
dramon
2011 JK Wrangler
I don't know what "relay trigger" means,but I will connect DRL's ligts and wireless warn off-road lights(two pairs).
dramon is offline
post #12 of 15 Old 12-26-2014, 11:48 AM
DanFxr
2010 KK Liberty
KC light install
2011 Wrangler Sport 2 Dr,
I am going to install KC H iLights on the jeep.
I would like it to be on switched power, Run or Run acc.
Can the rocker switch power to activate the relay go right to The M7 ,and set the M7 to run/Acc setting?
Thank you
DanFxr is offline
post #13 of 15 Old 12-26-2014, 02:03 PM Thread Starter
ronjenx
ronjenx's Avatar
Thank you
Yes. Power from M7, through the switch, to the relay coil.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #14 of 15 Old 12-27-2014, 08:00 AM
DanFxr
2010 KK Liberty
KC light Install
Thanks ,this is the way I want it set up.
I have not had a chance to look at the jeep yet, what was a good point to pass the cables thru the firewall ,and did it require a rubber boot.
Lights were a Christmas gift.
DanFxr is offline
post #15 of 15 Old 01-27-2015, 04:14 PM
Taking2long
The rear windshield wiper fluid line that runs through the firewall on driver side. Just follow windshield washer hoses
Taking2long is offline
SprintBooster Selectable Power Converter..opinions. MacK JK Wrangler Technical Forum 15 08-25-2010 03:40 PM
Battery dies quickly with CB wired to accessory fuse box behind passenger glove box npike TJ Wrangler Technical Forum 13 04-29-2010 07:48 PM
ARB Compressor Power Source / Wiper Motor Power Wire Color? Lawdodge TJ Wrangler Technical Forum 4 06-28-2008 10:42 AM
Auto Power off Accessory SkipperTW JK Wrangler Technical Forum 0 07-21-2007 12:47 PM
Battery side posts for accessory wiring? Woodyhfd TJ Wrangler Technical Forum 9 01-28-2007 09:10 AM
