Hey guys, i need some help in replacing my fuse panel. All my wiring is in average condition. just dirty and old I guess. Reason for replacement is:
With head light switch on turn blinkers dont work. With head lights off turn blinker to the left works. With head lights off turn blinker to the right not so fast. It blinks the right front, right back, left back, and left back side light. I think the source is the fuse panel. (turn signal, headlight switch, dimmer switch is all brand new from o'reilly's or online)
Could you give me some options for repair:
1) I was thinking painless wiring harness, but don't want/have the money for a kit. If I was to go this route which painless kit should i get the more expensive that is pre terminal. or the one with no terminals.
2) Fuse Panel Replacement only, for less cost, but I can not just find a fuse panel. Any help Here? (also i prefer not used, so i don't return in the same spot months down the line does not have to be factory either)
3) Repair the original fuse panel, but where do i find the internal connectors, parts and pieces there to basically make the fuse panel brand new.
Thank you for the help!
