Its cold today in CO, (it is about 6 degrees). I started the YJ, drove about 2 miles and started smelling fuel. I found the fuel filter cover, hose, and driver side spring soaked in gasoline. Has my fuel filter given up? Could the connections be loose because of the cold? Or is it something else?
The Haynes manual says to remove the backpressure before removing the filter. How is this done?
