Well just bought a ford 9 inch housing and low pinion carrier,suppose to be off a 67 bronco and without the axles on or the brakes it measures 53 1/2 inches. Mine now AMC 20 measures 47 inches, but with the drum brakes and the 2 inch spacers it comes to 57 1/2 inches wheel mount to wheel mount.....It's a narrow track by the way. So, with that being said, I got the axles, just 28 spline, drum brakes, low pinion carrier in GREAT shape.... gears are shot of course, and housing already primed and painted with that black heavy duty paint.... the name escapes me right now, for 175$$$ So questions are after measuring it i am wondering if this is closer to a wide track axle. Quest #2 Should i stay with low pinion with a SOA set up...it is cheaper to just buy gears and stuff. Quest #3 Should i opt for the 31 spline.... I know the answer to this one..... and what is the best posi for me 80% road 20% moderate trail riding with the occasional mud pit. Need some help. It was a great deal for the stuff but will it all work for me. If its a wide track then i have to go find a whole front axle set up $$$$$$$$
like not to do that
like not to do that
