Engine Swap
252 views 10 replies 5 participants last post by  Renegade79
Replacing my 258, t150, Dana 20 in my 1979 CJ5 with this complete setup (258, t176, Dana 300) from a 1980 CJ5.
Question.
Will I need to alter anything besides possibly the driveshafts?
Driveshafts for sure. Transmission cross member will likely be in a different set of holes. Trans tunnel cover will need to be modified for different shifter locations. Maybe a few other minor things that I'm not thinking of.
Should be pretty straight forward.
If your t176 has the same shifter as my 1983, you'll need to trim your tub opening and get (or make) a trans tunnel cover. I replaced my tub with an aftermarket one and it had the tunnel opening precut for the t150 and other transmissions that we more centered. Here are some pics of where I needed to trim. Good luck with the swap!
