OK, I finally found my transmission to dump this SR4, and I'll be able to keep my Dana 300.
Now on to the Axles. I want to put D44's front and rear, and want to minimize my cost as much as possible..
First off I know I may not find a perfect no work required donor, but is there a better choice of donors that will give me the least amount of work to get them to fit under my '80 CJ7?
My skillset in this case consists of being a gofer to pick up and deliver the D44s, and I am able to remove the D30/AMC20 and if I get lucky with a direct bolt up D44 I can install it where the previous ones were.
As a second part to this question, do I really NEED D44's? I will be running the CJ7 strictly for trail use, I plan to do Moab at least once. For local trails I will likely drive, but further trails I will tow on all 4s, w/ Drive Shafts removed. If an axle does go I will either fix on the trail or rent a u-haul trailer to tow home.
I'll probably be on trails once or twice a month 8 or 9 months a year with 4 or 5 Jeep Jamboree trails a year. I am most likely keeping the i6, not decided on a stroker 4.0l or a 4.0l head on my current 258 yet. Tires will likely be 35's, and tranny is a 6.58 granny first. Might even look at a regearing the D300 to a lower low if that is even possible (not looked). But my target is as low a crawl gearing as I can manage to get.
I am regearing to 4.11 or 4.56, and installing ARB Air Lockers in both. The gearing and lockers are a given in either case.
I know the AMC20 can be beefed up. I know the D44's are stronger and better. I can gear and locker either set.
What I don't want to do is to get into a situation where I spend money on one set of axles only to break them and then have to spend the same money for the same upgrades with the D44s?
I've never used D44's, never installed them, or never worked on them. But everyone I used to trail with swore by them, and everyone I have ever known wishes they had them. This CJ7 will most likely be my last build, and I want it to be something to be proud of on the trails.
Any input would be appreciated.
