You need to read up on aerodynamics and pressure zones. The air behind the baseball bat has a stagnant area that tapers to a point, everything else flows around this teardrop shape.
Actually, I'm pretty familiar with them...but I have to admit that I wasn't looking for someone to critique the example to a level that most people would not be interested in comprehending. I really hate it when threads derail like that. :thumbdown:
However, you are correct in stating how the air moves and I have to thank you for clarifying my point, which is this:
an object like a winch - or a baseball bat, for that matter -
does not occlude the radiator behind it. Does it create a disturbance in the air? Sure it does...ANY object moving through a fluid creates signs of passage. But - as you pointed out - the area of still air tapers to a point and other air moves around this "dead space"...a fact which perfectly illustrates the fact that air can and does move around the winch. Yes, it can create some loss of airflow (depending on how far the "dead space" extends) but not enough to interrupt or cripple the functioning of a well-maintained cooling system.
My apologies for the over-simplification. :cheers2:
