Help connecting MSD 6A / 6AL / Street Fire 5520 to ZJ Grand Cherokee
Hello,
I ordered a MSD Street Fire 5520. This is similar to a 6AL except that it has slightly lower spark energy intended for street use.
The MSD's have the option of either magnetic trigger or "white-wire" points trigger.
The infamous white wire can be connected to a number of things. Obviously, for the ZJ, you'd want to connect it to the PCM output.
The '93 FSM says that pin 19 of the PCM is "DISTRIBUTOR IGNITION COIL ( - )". Pin 19 measured at the coil is +12V. It is the light-colored wire on the coil connector.
So why does it say "( - )" if it's really Plus?
The other wire to the ignition coil is shared by the injectors. It is the dark colored wire on the coil connector and it's +200mV.
Several people have posted success connecting the white wire to the ignition coil. This would only make sense if they were connecting it to pin-19, aka the light-colored coil wire.
The next question is what to do with the dark-colored coil wire? Leave it hanging?
Surely the proper way to solve this problem is with some kind of "isolating" "relay" that has the same Ohm resistance (1.0 Ohm) as the stock coil but has the action of shorting the white wire to +12V (MSD Red wire) when the ECU fires - ????
Thanks!!
(When I'm done I'll give a full write-up of the benefits (if any:laugh
and wiring.)
Here is an example of one of the MSD "modes" in the instruction manual:
Hello,
Thanks!!
