Comparison of fuel system cleaners
30K views 35 replies 16 participants last post by  Pine_Cat
We've all been hearing the hype of the different engine cleaners, from the traditional seafoam, to no brand injector cleaners, to name brand octane booster/full system cleaners..
I figured I'd make a list of some of the common and uncommon methods I've heard and maybe we can discuss our experiences with them? eh, here I go.
Here's some common ones. When one brand is listed, all of that brand are included.
Red Line Complete system cleaner
Royal Purple max clean
STP fuel system
3M Fuel Tune Up
Stabil Fuel Additives
Lucas Oil Deep Clean
Chevron Techron
FPPF fuel system cleaner
Gumout 104+ Octane Booster/Fuel Injector Cleaner
Cyclo C44 cleaner
ZMax Total Engine Treatment
Gunk M2616 Fuel System Cleaner
Hi-Gear Engine Treatment
Hy-Per Fuel System Treatment
Berryman B-12
Seafoam entire engine cleaner
Mag 1
Prestone AS790 complete fuel system
CRC fuel system cleaner
There's some rather unconventional methods I've also come across to cleaning out the fuel system.
DISCLAIMER!! some of the following may cause damage to your motors or other components. Some of these may be potentially deadly to mix. Please do not try these for the sake of your own safety unless it can be confirmed safe! And even then, use extreme caution! I can not be held liable for your own screw ups
Av-gas or other 125+ octane fuel
Mothballs into the gas tank
Acetone
Airplane paint stripper
ethanol alcohol(clear only)
Methanol alcohol
kerosene
Asprin(yes, the pain reliever)
paint thinner/mineral spirits
miniscule amounts of diesel fuel
There are others but I can't remember them or find them anywhere. Has anyone tried these in a Jeep motor and can either protest or back up the effectiveness of that treatment? Maybe now we can have a one stop shop for this info instead of having it scattered between 20 different threads every couple months.
I've used several of these over the years and different vehicles. The ones I would personally recommend are 3M, Gumout, Seafoam(most recommended for once a year deep cleaning), Stabil and STP(my regular, once every few tanks or so additive).
I noticed major improvements with the seafoam, STP and gumout in my vehicles. I didn't really notice any kind of improvements with 3M or Stabil as far as fuel system cleaners. Stabil is great for keeping your fuel from turning to crap from being watered down though.
How about all of you? Do you have any experiences positive or negative with any of these? I'm curious as to if anyone has tried the more uncommon methods successfully or knows of others that are "miracle cleaners" that are also safe for the O2 sensors, AIC, etc
Didnt someone post a few days back according to "some engineer" about using 50/50 DOT3 & water for an engine clean when discussing a plenum / engine clean? sure i have it bookmarked .... somewhere:)
Look at the MSDS sheets for any cleaner you put in your car, half of them are basically just naptha! I use Redline SI-1, very high in cleaning agents (Poly Ether Amine), and the official fuel system cleaner you'll be given by BMW if you ask for some...
The Redline is my go to cleaner of choice.
I use the Techron and it seems to do a good job. I've added it before long trips and gotten a 2-3 mpg boost in the first tank. The mileage dropped with subsequent fill ups though. I also once took my dads car to the beach; 15 mpg down; dropped in a cheap gas station bottle of STP; and got 20 mpg on the way back.
The primary ingredient on them might be naphtha but that's probably just to dilute the stuff so it can be poured. I use whatever is the cheapest fuel injector cleaner at the time when I run injectors through my ultrasonic cleaner. I use naphtha as the working fluid and I know from experience that adding the cleaner makes the mix less pleasant to work with. Really eats the oils out of your skin.
Techron does have a comparable amount of PEA to Redline, so worth using, unlike some of the other trash about!
TBH if you're using an ultrasonic cleaner I would just use straight gas or white spirit - I have one too, that's what I use, and it doesn't seem to make a difference if I add a cleaner. It's the vibration that does the cleaning, not so much the fluid.
BTW by "white spirit" I mean what you filthy foreigners might call ethanol, straight alcohol - I use Methylated spirit, which is the same stuff but with Methanol added to stop the drunks buying it. Over here, "White spirit" is actually a replacement for turpentine as a paint thinner/brush cleaner for oil-based paints. But I think you call it "white spirit" or "white gas"? The stuff you use in a Trangia camping cooker, anyway!
edit - apparently you call it "denatured alcohol" over there.
White gas here is naphtha which has about the same weight fraction as gasoline but without all the additives. We use it in our Coleman camping stoves :)
What you are calling "white spirit" we would just call ethanol. Your "methylated spirit" we call denatured alcohol.
So redline, seafoam and techron are the favourites in this crowd so far. We could get this going a few pages, I'm sure ;)
#17 ·
I'll add Lucas gas treatment every couple months. While the info/chart below is a couple years old (2012) supposedly there's no need to add alcohol-based fuel treatments to E10 fuel. Kind of makes sense since sure don't want there to be suggested E15 fuels which damages/overheats small engines.
http://www.fueltestkit.com/is_gas_additive_safe_with_e10_list.html
#18 ·
I like Techron, never tried (or seen actually) redline around here. Seafoam I run through the intake every so often, though I don't know if it does anything honestly :p. I think I tried gumout once and it did absolutely nothing.
#20 ·
Seafoam
/end thread
#21 ·
im a strong believer in octane boost and clean combustion. gents once you have cleaned everything out switch to straight gas with octane boost to keep it that way. ethanol blended fuels are bad for our motors,fuel systems,sensors etc
here in canada our reg gas is 87 octane 15% ethanol/butane/gasline antifreeze,, mid grade 87octane, and prem 91 no ethanol. i run shell V-power with stp or lucas octane thru all gas motors i have.attached a write up on it. didnt mean to highlight page.. cheers
#25 ·
Interesting if your reg gas up there is already E15 and it's just starting to show up at some stations down here. Our mid or "plus grade" gas is 89 octane and maybe the same up there?
I'll never run E15 in my chain saws, weedeaters, back-pack leaf blower, mowers, generator, and other small gas engine equipment. And it's strange to see cats installed on many new generators, mowers, some other small gas-powered equipment, which is a mandate.
Fed warning sign which is supposed to be installed on the E15 gas pumps.
I'm a firm believer in using Sta-bil in the gas cans for stored fuel for my generator. Have to keep at least 5-10 gals around to prep for power outages since I live in the woods and trees do come down on the electric lines.
I used to use both STP and Gum-out fuel injector cleaners in our Jeeps but didn't seem to do a whole lot so switched to Lucas. Found Lucas to be a whole lot cheaper if you buy it in the gal jug then use the small bottle for measuring it to add to a full tank of gas.
#27 ·
The smoke you see after putting Seafoam in your plug holes and letting it sit, then firing it up - it's the pale oil burning off. Not removing carbon or anything else.
If you really want to clean your carbon deposits out, get the engine warmed up then feed a pint or two of water in through a vacuum line, bit by bit - the water flashes into steam, breaks up the carbon, and it comes out the exhaust.
For best results, do it with the tailpipe close to a nice white wall. It won't be white any more after doing it - but you can always hose it off.
Ever seen the cylinder of a car with a blown head gasket, where coolant has been leaking into the cylinder (s)? Sparkly clean, like a new engine.
Just remember to change your oil soon afterwards.
#24 ·
I use the Lucas Oil treatment/cleaner whenever I actually remember to use it, which is probably once a month.
#26 ·
lucas products are awesome! on my 99 sport i did a complete sensor replacement(tps,aic,O2s)
k/n intake, s/s header magnaflow cat/muffler 2 1/4" and run shell V-power with octane boost.
as well as full synthetic fluids in everything and wow what a diffrence from stock jeeps i wheel with
#28 ·
I did the water treatment a few times on my Jeep before the first Seafoam treatment. I do believe that water cleans carbon from the combustion chamber well enough but it doesn't do anything for the valves. I pulled the intake after the water treatment so I could change freeze plugs and the valves were still cruddy. After the first Seafoam it ran noticeably better. I've done the Seafoam three times in the last year and when I pulled my intake a month ago to swap for the 99 intake my valves and the inside of my intake were spotless. No carbon build up at all. I just bought a can of the aerosol Seafoam. Probably nothing left to clean in my engine but I'm going to give it a try soon.
#30 ·
O_O ...... $5.63 per gallon of premium gas... I don't think I have much room to complain about our $4 per gallon of premium anymore.. Where are you? I want to say Canadialand but not sure..
