I have a 64 CJ5, I had to park it outside overnight and now I can't move any of the shifters, transfercase, shfiter etc, so I can't start it cause it won't get out of first. it's like 20 degrees outside, could that be the cause?
A step farther. Up in the big AK, it is routine to swap out box (not diff) 90WT with 50WT. This greatly aids in cold weather shifting.79cj7reny said:You should still be able to push the clutch in and disengage the tranny to start it. If you can get it started and warmed up things might free up for you. Real cold weather can thicken the fluid (so to speak) and make it harder to shift. It's also possible that there is water in the fluid and the water has frozen.(Unlikely if you've changed the fluids) If pushing the clutch in won't disengage the tranny then something else is going on (maybe clutch disc stuck to the flywheel:dunno![]()
I would 'sure' be looking for water contamination everywhere!awalp said:just for an update, it was maybe 15-20 degrees, and it wouldn't even move with the clutch pushed in on a decent grade hill, but it got up to 40 and everything is fine again. that's in Fahrenheit for the non-US guys
