Engine turns over but will not crank. NOt getting spark from coil to distributor cap. I have 12v going into coil but no spark coming out. I have tested fuses both inside jeep and under hood(good). replaced coil, crank positioning sensor, and distributor. All voltage readings are within range on each. Diagnostic test comes back with 11, 12,33, 55. Took horn relay(working fine) out and put in automatic shutdown relay to test, still not spark from coil.
