I've searched the forums and still a little confused. I need to replace the bushing on my clutch pedal. I don't believe that I have to take out the whole assembly to remove the pedal. There is a snap ring on the pivot shaft that I need to remove, return spring, clutch linkage. Is this the correct procedure? The brake pedal works fine for now.
Any tips would be appreciated.
