can you pull camshaft without pulling head on 4.0?
2.2K views 13 replies 7 participants last post by  4.7stroker
92 yj 4.0. HO
i'm replacing the camshaft sometime next week. people tell me i need to remove the head to get to the lifters. i know in some engines though you can get a lifter remover tool and pull them out without pulling the head. if i could do that i don't see why i couldnt pull it out after that. can you get a tool to get the lifters out? anybody know anything about the process?
thank you.
actually the motor only has about 30k on it since it was rebuilt so that part shouldnt be neccessary, but anybody else got any suggestions on the job? also, about how much does the head weigh on this motor? i'm trying to figure out whether two strong young guys can get it out by hand or if i should go borrow my friend's engine hoist again.
Does an LS1 use hydro lifters?
Didn't know so I thought I would ask. You are probably correct in the aluminum helping out by not sucking the magnent out of position/canceling out the magnetic force.
Will the cam bearing journals clear the lifters if they are pulled up? On a 30,000 mile motor , like the OP has, the lifters should still be good and could be re-used. I figure this was a performance cam swap rather than a damaged replacement. Always use new lifters when replacing a worn cam, so the head would have to come off.
this is a performance cam swap. i have no running problems. however, being that it's a performance cam swap, i have to put in matching lifters for the cam, stock lifters won't work properly with the cam. i guess the bottom line is i'm pullin the head one way or another, i'm just hoping not to run into any issues with the actual pulling of the cam.
EABiker said:
Can you use pencil shaped magnets to pull up the lifters? That's an LS1 trick!
This may be true but you should always replace the lifters when replacing the camshaft.
Therefore yes you have to remove the head to replace the cam.
If there is any damage to the lobe of the cam it will have damaged the lifter, this will take ruin the new cam you are installing.
Please read the provided links.
Dwayne
