I've had some problems a few months ago where my Jeep would shut off when I stop. After some research I replaced my crankshaft position sensor and camshaft position sensor with OEM parts.
After that I was driving fine again for about two months, then my service engine light came on stating the camshaft position sensor was bad. I took it to a shop and they checked both the sensor and the wires, and said the sensor was bad. So I swapped out the sensor for another new OEM part and two weeks later I was having issues again.
So this time I figured I'll just try cleaning the part with some electrical contact cleaner, and that worked!.....until today. Same issue, same code.
I read I could try cleaning it and then adding some dielectric grease, but I'm curious if anyone else has some ideas I could try.
