bcm pin out diagram needed
17K views 6 replies 4 participants last post by  damessor92
im looking for the bcm pin out diagram to make sure that my bcm is bad. any help would be appreciated
body control module c1 - gray 26 way cav circuit function
1 z2 20bk/or ground
2 g52 20yl headlamp switch mux
3 e19 20rd panel lamps dimmer signal
4 - -
5 g70 20br/tn hood ajar switch sense
6 g26 20lb key-in ignition switch sense
7 g76 18tn/yl door ajar switch sense
8 e2 20or panel lamps driver
9 e2 20or panel lamps driver
10 e2 20or panel lamps driver
11 - -
12 e2 20or panel lamps driver
13 e2 20or panel lamps driver
14 z2 20bk/or ground
15 l80 20wt/dg pci bus
16 l80 20wt/dg headlamp switch return
17 d19 20vt/or body control module flash enable
18 - -
19 - -
20 g69 20bk/or vtss indicator driver
21 l7 18bk/yl park lamp relay output
22 v14 22rd/vt wiper on/off relay control
23 m20 20br/or courtesy lamp load shed
24 m2 20yl courtesy lamp driver
25 z1 20bk ground
26 - -
body control module c2 - white 22 way cav circuit function
1 c103 20dg a/c switch signal
2 v10 20br washer pump switch sense
3 - -
4 l40 22br high beam switch sense
5 v11 20bk/tn washer fluid switch sense
6 p134 20lg/wt passenger seat heater switch mux
7 p133 20lg/rd driver seat heater switch mux
8 x20 20rd/yl radio control mux
9 c8 20dg/rd ambient temperature sensor signal
10 l109 20wt ultralight sensor signal
11 v52 22dg/rd windshield wiper switch mux
12 c15 20bk/wt rear window defogger switch sense
13 - -
14 - -
15 l27 22wt/tn fog lamp switch sense
16 - -
17 g18 20pk/bk coolant level switch sense
18 p132 20or/bk seat heater switch sensor ground
19 x10 20rd/bk radio control mux return
20 g39 20db/or ambient temperature sensor return
21 l110 20bk/yl ultralight sensor return
22 v59 22db/yl windshield wiper switch return
When the key light comes on it means your transponder key is not being recognized. If you have a second key try that and if that does not work it could be the immobilizer unit on the steering column.
alright started out by changing out my main body ground and tried that since I finally got time to work on it. and I haven't had an issue since im going to go through and change out all the grounds and put a better wire in though im still having issues with it though no alarm and not keeping track of fuel mileage.
