This is a "how-to" for a really simple repair. A '98 XJ 4.0L/automatic/NP231 came in the shop with a clunking noise in the driveline. The transmission mount was extremely collapsed & the exhaust system mount bracket (located between the transmission mount & transfer case) was hitting the crossmember.
Here's how close it was at rest, and some pics of the general condition of the mount.
I used a floor jack & a block of wood to support the case while replacing the mount.
A 13MM socket was used to remove the 4 nuts that attach the transmission mount to the crossmember.
The crossmember is attached with a 15MM nut & bolt on each side.
An 18MM head bolt is located on the left & right side of the mount, attaching it to the transfer case.
Here you can see the exhaust mounting plate that is sandwiched between the mount & the transfer case.
Replace the mount with the new one & tighten the 18MM head bolts.
Reinstall the crossmember onto the mount using the four 13MM nuts at the center, and the 15MM nut & bolt on each end of the crossmember.
I used anti-seize on the 15MM crossmember nuts & bolts.
Here you can see the extra clearance gained by istalling a new mount, and best of all there is no more clunking!
Max :cheers2:
Max :cheers2:
