Anyone replace a tpms sensor by themselves?
12K views 11 replies 8 participants last post by  bts_wk2
#1 · (Edited)
So went to dealership for state inspection. Informed them that the tpms sensor in right front tire is bad. It will display wrong psi and light will come on. Well I go to pick up my jeep and read the paperwork and they never replaced the sensor. Service writer says mechanic said light was not on so they could not replace it. The light has been on for 2 months. So as soon as I drove out of the lot what happens THE LIGHT CAME ON. Now indicating the right rear tire is low since I had the tires rotated while it was being serviced. I am so sick of dealership crap thats why I no longer am a mechanic. The only reason for going to the dealership was because I bought the jeep there and still had several months left on the warranty. Sorry for the rant but has anyone attemped to replace a tire sensor? I think the hard part may be unseating and reseating the bead on the tire.
Thanks
I bought a whole new set off eBay for my winter tires. Installed them in the winter rims and they work flawlessly. Don’t even have to reprogram anything when I change tires each season. Jeep learns the new sensors without missing a beat.
So... yes, you can definitely replace them and the Jeep will learn the new sensor on its own without any programming at all.
Yes hard part is the tire thing. A tire shop will remove the tire, replace the sensor, clean it up, and install/balance the tire. Local tire shop charged me $20 labor to do one (I provided the sensor). They like to sell you their sensor, however.
If the sensor/stem is corroded you may have to cut it off. Recommend OEM sensors as those seem to be less trouble. Often you find them on eBay for a good price. The OEM sensors may be loosing battery charge, it may be prudent to change them all... but many here just live with the icon.
The bad sensor probably has a marginal battery, it should eventually die altogether, especially in colder weather.
I purchased 4 sensors off ebay and one finally failed after 3 years. I went to my local Discount Tire and paid the same amount for one sensor as I did the 4 from ebay, but it carries a warranty through them, so I figured it was worth it.
I personally wouldn't mess with it, they'll change it out for cheap and have the proper tools.
TPMS replaced
my WK2 Limited 2012, got rear left TPMS error one day. It trigger error message on the dash, and keep blinking att the time. Go to dealership, and replacement part cost me $110, refused, and go to amazon and found $14 oem part. Bought it and bring to local tyre shop, and got it replaced. Run the car, within minutes the error message dissapear. Computer sensing the new TPMS quickly, no relearn procedure required
I too have purchased sensors online, and they've worked great. However, I've been in a couple of tire shops recently that had posted signs saying they will no longer install carry-in sensors, only the ones they sell (even a shop that did this for me previously). I guess they're missing the markup on these parts. So I guess before you buy, make sure you can get them installed.
