There is a book of steps in the FSM. I'd suggest getting a three day pass from tech authority and download what you need.
Here are the removal steps for the cover, most of these have dozens of steps nested below:
Remove the floor center console
Disconnect and isolate the negative battery cable.
Remove the steering column assembly
Remove the left end cap
Remove the left and right side cowl trim panel
Remove the instrument cluster
Remove the radio
Remove the instrument panel storage bin
Remove the A-pillar trim panels
Remove the HVAC ducts on left and right A-pillars.
Using trim stick, separate the retaining clips and remove the defroster grille
Disconnect and remove the center dash speaker.
Remove the glove box
Remove the right silencer panel
Remove the instrument panel cover screws around the center dash, around the perimeter, and around the passenger air bag support from the instrument panel reinforcement.
Remove the instrument panel cover from the instrument panel reinforcement disconnecting any electrical connectors as needed.
Remove and transfer any parts from the cover as necessary.
Edit: it seems that the cover is not sold separately, the entire instrument panel structure gets replaced, about $700 from discount dealers. The PDF will show replacing the panel, similar to the above.
