My jeep has had a small tick coming from the valve train since I bought it. I changed the oil in my jeep for the first time since I have owned it this last weekend and the tick has gotten noticably louder now. I am running 10W-30 with some Marvel Mystery in it, I can only assume the PO was running heavier oil to help mask how loud the tick was.
This coming weekend I am going to pull the valve cover off and scrape off all the blue RTV that was used (no gasket) and check out the rockers. I know there is a long list of things to look as to what can be causing the tick, especially when taking over some persons previous project. I am just looking for a few of the normal culprits to check for. I am hoping it is just a worn pivot (seems fairly common when I searched) or something easy and cheap to fix.
We are also going to install the HEI, new plugs, check the compression and set the timing. Any and all advice is appreciated. Thanks in advance!:cheers2:
