1 - 20 of 28 Posts
agear
1984 jeep cj7 laredo
Discussion starter · #1 ·
Since the engine came from just some guy I don't know what year the engine is. I have the 8I2CL03 stamped onto the side of my engine block. I'm trying to find out what the numbers mean. Anybody ?
Discussion starter · #4 ·
Are you sure the second digit is an I and not a 1? Somebody on another posting site has the same number, Here is what they came up with.
Link to thread: http://www.pirate4x4.com/forum/showthread.php?t=650456
Then it could be 8(made in 1975) I2(december) C(258 2bbl) L(light block) 03( on the 3 day of december.
If you want to double check: http://webspace.webring.com/people/dg/geer_hed/cj_numbers.html#block
That's syncrhonistic because I ! posted that there a long time ago.
Well I went out to my jeep and on the drivers side I found this number EF 3235444
Which if I go here http://webspace.webring.com/people/dg/geer_hed/cj_numbers.html#block
The 3235444 says its from an 1981 - 1985 if they mean by 7/16ths head bolts they mean the studs with nuts on them in the heads.
Discussion starter · #6 ·
Trying to find a good exploded view of a 258. Are they all under the valve cover ?
because it is 7 digits that is a YJ block made Dec 3, 1988, the 4th and 5th digit letter code "CL" is listed in the YJ FSM as "engine type/fuel system/compression ratio" but it does not list what the various letter codes designate.
Discussion starter · #9 ·
Really ? Where did you see that if it was 7 digits it's a yj block ? Where are the head and crankshaft casting numbers found ?
I read it as December 3, 1988, C is a 258. The L not real sure about. Maybe Mopar added the L so they could tell if it was a from AMC or a 88 that they made. Just a guess on that one.
That would be unnecessary - 1987-early 1988 6-242 blocks have the AMC logo as a casting mark, late 1988-up 6-242 block have the Chrysler pentastar logo...
Discussion starter · #11 ·
Well like I said i have this on the drivers side of the engine block -EF 3235444 . And if you go here http://webspace.webring.com/people/dg/geer_hed/cj_numbers.html#block it reads it could be an amc from 1981-1985 258 4.2 3.75 L-6 7/16" Head Bolts or the next one reads it could be an amc from 1986
258 4.2 3.75 L-6 1/2" Head Bolts or the last one reads it could be an amc from 1987-1989 258 4.2 3.75 L-6 2.06" Crank Neck, Spec. if Alum. or Plastic Valve Cover, 1/2" Head Bolts
Now in the pictures i've attatched you'll see the bolt (or stud) I checked the diameter of . It was 7/16ths
so what do you think ?
Discussion starter · #12 ·
To confuse you a little more. Supposedly the head is from a different year.
The top of those studs is usually threaded 7/16" - the underside can be either 7/16" (early, probably before 1975) or 1/2" (late, and definitely on the 6-242) - SAE Coarse in all cases.
I know the 6-242 blocks had the logo changed, so I see no reason to suspect that the 6-258 had it changed as well (I've also seen AMC V8-360 blocks in SJs in late 1988-1991 that had the pentastar logo as well. It's a simple change to effect in the moulds, so there's no reason to not do it across the board. The 4-150, I'm sure, did the same thing as well.)
Discussion starter · #16 ·
5-90 typed "The top of those studs is usually threaded 7/16" - the underside can be either 7/16" (early, probably before 1975) or 1/2" (late, and definitely on the 6-242) - SAE Coarse in all cases"
5-90 You just had to tell me that didn't you :laugh:(kidding)
But I think it's a 258
The only blocks with 1/2" head bolt holes were '81-85. Anything older or newer than those years was 7/16".
Not so, it is just the opposite. 81-85 have 7/16" head bolts. late in 1985 the head bolts got changed over to 1/2" for the 1986 model year and beyond.
1975-79 head bolts were 1/2" also. 1980 was a bastard year, either 7/16' or 1/2".
1 - 20 of 28 Posts
