Let me try this one last time. When they are referring to the "instrument panel", they are referring to the ENTIRE dashboard. The actual instrument panel with the speedometer, temp gage, etc., comes out in under a minute, but once it is out, all you can see are the are ducts underneath the dashboard. There are no visible screws to remove. See the beginning of your long post: "There are two defroster air outlets (1) located on the top of the instrument panel (2)." The defroster outlets aren't on the 'instument panel', they are on the dashboard. This is how it has to be done:
ASSEMBLY-INSTRUMENT PANEL
REMOVAL
1. Before proceeding with the following repair procedure,
review all warnings and cautions. (Refer to
23 - BODY/INSTRUMENT PANEL - WARNING)
2. Disconnect and isolate battery negative cable.
3. Remove the bolts (3) and remove the drivers side
hush panel (2).
23 - 80 INSTRUMENT PANEL WK
4. Using a trim stick C-4755 or equivalent, separate
the upper clips and rotate the cover down and
release the lower hinges at the bottom and remove
the opening cover.
WARNING: BEFORE SERVICING THE STEERING
COLUMN THE AIRBAG SYSTEM MUST BE DISARMED.
FAILURE TO DO SO MAY RESULT IN
ACCIDENTAL DEPLOYMENT OF THE AIRBAG AND
POSSIBLE PERSONAL INJURY. (Refer to 8 - ELECTRICAL/
RESTRAINTS/DRIVER AIRBAG -
REMOVAL).
5. Remove the three bolts in the lower shroud (2).
NOTE: Use care not to break off the tangs on the
shrouds.
6. Then unsnap the lower shroud (2) from the upper
shroud (1).
7. Disconnect the steering column electrical connectors
(3).
WK INSTRUMENT PANEL 23 - 81
8. Remove the pinch bolt (2).
9. Remove the column support bolts (1).
10. Remove the column cross bolt (1) and slide the
column (2) downward off the bracket and remove
the steering column.
11. Remove the nuts (1) attaching the instrument
panel to the pedal support bracket.
23 - 82 INSTRUMENT PANEL WK
12. Using a trim stick C-4755 or equivalent, remove
the ignition cylinder bezel.
13. Remove the screws (2) and remove the ignition
cylinder (1).
14. Disconnect the electrical connector.
15. Using a trim stick C-4755 or equivalent, remove
the left side cover.
16. Remove the left side door sill trim.
WK INSTRUMENT PANEL 23 - 83
17. Remove the drivers side cowl trim panel.
18. Disconnect the electrical connectors.
19. Disconnect the electrical connectors.
23 - 84 INSTRUMENT PANEL WK
20. Remove the bolts and disconnect the ground
wires within the steering column opening to the
left of the steering column.
21. Disconnect the white adjustable pedal electrical
connector.
22. Remove the bolts (2) and remove the left a-pillar
trim.* Right side shown, left side similar.
23. Remove the two left side bolts and one screw at
the a-pillar support.* Right side shown, left side
similar.
WK INSTRUMENT PANEL 23 - 85
24. Using a trim stick C-4755 or equivalent, remove
the shifter bezel ring.
25. Using a trim stick C-4755 or equivalent, remove
the shifter bezel.
26. Remove the center console back cover (2) and
disconnect the electrical connector (3).
23 - 86 INSTRUMENT PANEL WK
27. Remove the screws (2) and remove the console
(1).
28. Disconnect the electrical connectors under the
console.
29. Open the glove box and push the stop tabs down
to drop the glove box out of the instrument panel.
30. Rotate the box down and release the door hinges
(2) at the bottom and remove the glove box.
WK INSTRUMENT PANEL 23 - 87
31. Remove the passenger side hush panel.
32. Remove the right side door sill trim.* Left side
door sill trim shown, right side similar.
33. Remove the nut (1), separate the right cowl trim
panel and remove.
34. Remove the right side end cap.* Left side end cap
23 - 88 INSTRUMENT PANEL WK
35. Disconnect the electrical connectors.
36. Remove the bolts and remove the right a-pillar
trim panel.
37. Remove the two right side bolts and one screw at
WK INSTRUMENT PANEL 23 - 89
38. Using a trim stick C-4755 or equivalent, remove
the defroster grills (2).
39. Remove the two fenceline nuts (1).
40. Using a trim stick C-4755 or equivalent, remove
the radio bezel.
41. Using a trim stick C-4755 or equivalent, remove
the center bezel and disconnect the electrical connectors.
42. Remove the nut from the HVAC support stud
behind the center bezel.
43. Remove the screw to the HVAC from under the
glove box opening.
23 - 90 INSTRUMENT PANEL WK
44. Remove the HVAC bracket bolt from the glove
box opening.
45. Remove the left and right center support brackets.
* Left side shown, right side similar.
46. Remove the center floor duct (3).
WK INSTRUMENT PANEL 23 - 91
47. Remove the radio.
48. Remove the two HVAC bolts from the radio opening.
49. Remove the instrument panel assembly.
