Kyle's TJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Kyle's TJ Build
Labor Day Sale at UCF!Gibson WK HEMI 3" Catback - 5 Day Special!Ruffstuff XJ Unirail Channel Reinforcement....
Unread 04-23-2015, 10:41 AM   #1
_Kyle_
_Kyle_'s Avatar
Kyle's TJ Build
Well, as a sort of log and way to keep everything in one spot, I figure I may as well start a build thread. I am picking up a 2005 TJ Wrangler from a friend of a friend this weekend to turn into my weekend toy. It's got just shy of 180k on the clock and has the 6-speed.
It has a few rust issues, but otherwise is pretty solid. My main plan is to armor it and lock it, with plans on keeping it still able to be driven on the road to get to and from the trail (at least for the next 6-9 months until I can get a trailer/truck setup).
After speaking with XTRyan from Extreme Terrain, I am gonna go ahead and give Barricade a try. Today I ordered their front Tube Fenders w/ Flares, rear Fenders, and Rocker Guards with Sliders. I'll go ahead and sort out the rocker rust to prior to installing the Rocker Guards.
Sliders
Front Tube Fenders
Rear Fenders
With the installation of the sliders, I want to remove the body lift and just run the current 2" spring lift with 33s, for the foreseeable future. I may go to 35s down the road, but not anytime soon unless they are free or something.
Long Term I wanna complete this armor and then get into lockers. As of now I am planning on Detroit TrueTracks front/rear for the Dana 30/44 axles. After that step, I will be buying a cage - either a full Poison Syder cage or the Blue Torch Fab half cage. Beyond that step I want to look into front/rear bumpers and a winch (no plans on what brand that'll be yet though). I also have some odds and ends I want to complete such as removing the carpet and doing a DIY bedliner (suggestions?) and investing in the waterproof Bestop seat covers to get the cloth seats in good shape.
Any input or suggestions through out this process will be appreciated!
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
Kyle's TJ Build
_Kyle_ is offline   Reply With Quote Quick reply to this message
Unread 04-24-2015, 05:19 AM   #2
_Kyle_
_Kyle_'s Avatar
Side note...Is there any one interested in these existing flares when I go and take them off?
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 04-26-2015, 05:58 AM   #3
_Kyle_
_Kyle_'s Avatar
Well yesterday was the big day and I brought it home. First order of business was ditching the body lift. I could only shift into 1-3-5 and not 2-4-6-R because it was hitting the tub. I had already planned on removing it, so this just sped up the process. Overall it went pretty smoothly and we didn't see any major hack job issues.
I do plan on selling the 3" body lift if anyone is interested...
During the course of things we found out the front driveshaft had been removed and they thought the double cardan was bad but inspecting it showed it to be in great shape. However, spinning the yoke by hand yielded a lot of slop. We pulled the cover to find some vintage fluid and lots of visual slop in the pin/gear...so we are tearing that out today and putting in the true track we had laying around. The front u joints are also toast on the half shafts and we are gonna inspect the hubs and replace them if needed too.
We pulled the rear cover and besides the vintage fluid, everything checked out ok.
I also need to figure out why the front fender marker doesn't get bright. It only flashes dim causing it blink really fast. Granted it's good away in a few weeks when my tube fenders come, it's kinda annoying. Side note...if anyone wants to buy my tub fenders, let me know!
Otherwise the next step is going to be getting that rust neutralizer and hitting the tub and outside of the frame to get after what's already there. Going to have a buddy look at the stereo and sound bar speakers as well while we wait for my armor to arrive so we can start installing that. I also wanna get an upgraded steering kit before my trip in June as they have several trails you cannot ride with out it. I'm also leaning towards a cover instead of a bikini top/seat covers for the summer as that would only be about $90...
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 04-27-2015, 05:34 AM   #4
_Kyle_
_Kyle_'s Avatar
Definitely a productive weekend...swapped out the front differential internals with a true track to correct that issue, ended up finding out the front u joints we toasted so I also replaced those. Removing the body lift solved my shifting and linkage issues, but now I need to reconnect the transfer case linkage and front driveshaft once I finish this shake down run. Also found out the rear drum setup was toast that that was all replaced. The rear differential was inspected and we replaced the fluid...it looked awfully metallic and after 150 miles last night was almost too warm to hold your hand to. I think it is also on its way out so I will probably be buying another true track next week and proactively swapping it out in advance just so it doesn't grenade. My immediate to-do list is:
  • Fix passenger door hinge/have all hinges blasted and painted - Ordering replacements 5/11
  • Determine what the fan is rubbing/or what pulley is making noise
  • Change the oil
  • Change transmission fluid
  • Change transfer case fluid
  • Flush the coolant.
  • Determine is my rear wheel cylinders are leaking or if the axle seals are leaking - replacing wheel cylinders 5/12
  • Fit in the right head unit and fix the sound bar speakers
  • Acid/seal the tub rust that I can get to
  • Doing the same for the frame as time allows
  • Installing rear flares and rocker guards when they arrive this week
  • Installing my front tube fenders when they arrive
  • Ordering parts for the rear differential to swap it out in the next 3-4 weeks
  • Fixing the electrical issue that causes constant beeping when the headlights are on (believed to be a bad ground at the radiator)
  • Ordering/upgrading the front steering (rugged ridge kit maybe) - Ordering Currie kit 5/12
  • Fixing the leaky steering box (replacement?) - upgraded cylinder assist kit ordered
  • Reconnecting the transfer case linkage and front drive shaft
  • Figuring out why the AC fuses are all removed and if the AC works
  • Figure out why we the dash selector only blows air out the windshield vent and no other vents
I would have taken more photos but I was pretty dirty and a working like mad to get everything done while I had an extra set of hands to help me... EDIT: NOTE - Oil Change ~180400 miles.
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 04-29-2015, 12:03 PM   #5
97Heep
97Heep's Avatar
you by chance throw in the front fenders with the flairs?
'97 Jeep Wrangler Sport TJ 4.25" lift 33x10.5x15 KM2's (Sold)
'04 Jeep Wrangler Rubicon TJ - She's Savvy
97Heep is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 05:39 PM   #6
_Kyle_
_Kyle_'s Avatar
My plan was to keep the inner fender when I go to tube fenders but cutting away the existing fender... It would be significantly more expensive for me to go to a whole new tube fender
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 04-30-2015, 06:01 PM   #7
_Kyle_
_Kyle_'s Avatar
Looks like I will be going ahead and ordering mostaliner for the inside tub tonight and using the free quart of chassis saver on the outside of the tub to clean it up and pain over any of that surface rust after prepping it with a DA grinder or something similar.
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-02-2015, 07:17 PM   #8
_Kyle_
_Kyle_'s Avatar
Crossed some more items off the list tonight!
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-08-2015, 03:26 PM   #9
_Kyle_
_Kyle_'s Avatar
More and more parts have arrived...
I let me best friend borrow my Jeep for the weekend while I'm out of town and he got to try my new Bestop cover and said it works great, its just a little tight in the back.
I went ahead and ordered a steering box from Davey's to have sent to West Texas Offroad for the Stage II hydro kit. I don't plan on installing the rams for a while, but i'll at least have the parts. To compliment that, I am thinking of getting the Currie HD kit as well a it's only a little more than the Rugged Ridge kit.
West Texas Off Road - Hydro Kit
Next week I hope to take the drivers floor pan out to weld in the new one and get the lining done. I also wanna cut out the rocker and put the sliders on. I will probably hold off on the rear fenders until my front tube fenders arrive in hopefully the next month. I also have that continuous list of odds and ends to accomplish as time allows - but working 60+ hour weeks and taking two grad level classes makes it hard to find time.
The next big purchase is going to be a cage kit...
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-08-2015, 04:05 PM   #10
bobthetj03
Good call on loosing that hideous body lift.
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is online now   Reply With Quote Quick reply to this message
Unread 05-08-2015, 05:04 PM   #11
_Kyle_
_Kyle_'s Avatar
That was the first thing to go! And I even sold it!
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-11-2015, 09:10 PM   #12
_Kyle_
_Kyle_'s Avatar
Got the coolant flushed today and found a puddle of brake fluid at the back tire so I'll be doing wheel cylinders tomorrow and getting the parking brake setup...however I need to find a good diagram.
Also decided on the Currie steering setup and managed to salvage one of my hinges so I only need one replacement and a new pin now...
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-13-2015, 02:37 AM   #13
_Kyle_
_Kyle_'s Avatar
Last night i didn't get anything done besides organizing the garage because we did shocks on my buddies GTI. I did order a new hinge,
pick up replacement wheel cylinders. And ordered the self adjuster cable since Autozone no longer carries it.
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-13-2015, 02:39 AM   #14
_Kyle_
_Kyle_'s Avatar
And I ordered my Currie steering kit!
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 05-13-2015, 07:34 PM   #15
_Kyle_
_Kyle_'s Avatar
Which showed up today lol
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
