Since this thread is about CAI's and filtration, all obviously in an effort to gain a little more power and quite a bit more noise, I thought I throw this little tidbit out, FWIW. Certainly we're all aware that all filters are not created equally, and the same applies for filter material and filter area. This info. comes from the July 2013 edition of Mopar Muscle Magazine in which they cited the horsepower and torque losses caused by the various engine accessories......Power Steering Pump, Water Pump, Alternator, Paper Element Air Filter, High Flow Air Filter, and 5W20 oil vs. 20W50 oil. Since we're just talking filters here, that's all I'll show. They first ran the engine on a dyno with NO filter at all to get a baseline and then ran it with a 3 inch paper filter and finally with an AirAid 4 inch tapered, high flow filter. Here are the losses caused by the two types of filters when compared to the baseline (no filter) configuration. Horsepower and torque losses are based on "Peak" dyno numbers:
Paper Filter Loss: 14.4 horsepower and 10.4 lbs. ft. of torque
AirAid High Flow Filter Loss: 5.9 horsepower and 5.5 lb. ft. of torque
So, if you're running your engines at WOT all the time, you'll do better with the high flow filter than with the stock paper one.....but I think we all already knew that.
