Howdy all,
I have searched on this topic but most ABS issues I have found just say the problem is that the ABS light is on with no physical brake issues mentioned. But it's possible I missed it.
Here's my WJ's brief history and ABS problem. I bought a 2001 WJ Limited with the 4.7 and QuadraDrive in October 2019.
The ABS still seems to function. I did a test on an empty stretch of back roads. I was doing about 40 MPH on dry pavement and stomped on the brakes with both feet as hard as I could and they did not lock up. No change to the above describes ABS issue either.
Thanks for reading and for any ideas.
And Merry Christmas / Happy Holidays
- I did a full brake rotor and caliper change from the Tevis to Akebono calipers. Only issue was a soft brake pedal, it took a few bleed attempts before I got a more solid pedal. No issues with ABS light.
- I then installed a 3" IRO lift from Kolak (thanks Kolak :laugh2
. I suck at taking progress pics so I have not posted a thread on it. The lift included all new springs, Bilstein shocks, track bar, sway bar links, and a new Addco rear sway bar. I have driven the WJ several hundred miles since the lift install, including a good 60 miles of off-road trails. No issues with the lift or brakes.
- ETA: Installed new ball joints, tie rod ends. More on and off road driving with no ABS issues.
- Then since my right front axle shaft had a torn boot and some subtle noise from that side (existed when I bought the WJ), I changed out both front axle shafts with Detroit Axle shafts. Here's where the ABS issue started.
