So after a long battle with with no OD on my 42re I had a transmission shop “fix” it. I just picked it up Friday and drove two hours home. First gear seemed to hold a little long, but Overdrive worked again so I was happy. It was pretty much a full rebuild.
Today though we took it for a road trip and an intermittent previous issue reappeared. Driving down the canyon (about a 1500 ft elevation drop over 30 miles) it seemed like it went into neutral, at about 40mph after coasting into curves and then accelerating. Prior to having the rebuild when it happened I would run the shifter thru the gears and it would eventually have the 3 existing gears again. This time I realized 1st gear was the only gear working and at 40 mph the rpms were high and why it seemed like it was neutral but was actually 1st at too high of a speed. 1st was rebuilt and maybe why I could feel it this time. I stopped and turned the motor off to see if fluid was pouring out or something obvious. When I turned it on, everything shifted perfect, we put a 100 miles on it up the mountain and back down.
A quick google I found mention of OSS and realized the symptoms were the same as one time 6 months ago when I unhooked the sensor to test for overdrive issues.
This same issue happened a couple of times in the same canyon on the day I drove it to the transmission shop originally. It seems like on “coast” into a curve and then accelerate the transmission becomes confused and goes into OSS limp mode (not the real limp mode). There is also a chance that I have to brake in the curve when it happens, I remember being stuck behind a slow driver that was riding his brakes (I normally coast), which got me to wondering about the relationship of ABS and OSS. Wondering if a problem between them might make the PCM freak out?
I will call the transmission guy on Monday but was was wondering if anyone had heard of a similar irregularity? It obviously doesn’t happen everytime, but when it does happen it is sharing similar conditions. This is the third or fourth OSS sensor over two years and I put a new pigtail on when I inspected the wiring harness, but this would happen before the new pigtail too. I’ve even considered the weight shift of curves is making a wire shift and short.
Maybe it’s something the mechanic missed and will warranty, but if not, I really don’t want to give him more money for him to look for a nick in a wire. It’s already cost more than the original price of the Jeep.
