its easier than you think, i did mine with the fan out (was also replacing it) so it made it easier, and i also used the GMB new (not reman) water pump from advance, only advice ill give you is DO NOT just use the gasket, put some rtv (they will give you the right stuff) on the pump where the gasket goes, then put the gasket on then put more sealant on top of the gasket, and like everyone else said, put the metal pipe on before you install the new pump (personally i just got a new pipe from the dealer, was about $20) and the bolt torque is 22 ft lbs on the bolts for the pump, id suggest while your in there getting a new t-stat, its an easy 2 bolts, and only use mopar coolant, should be there 5year/100k coolant
