2013 Jeep Grand Cherokee - 153,000K
Believe it or not, I have had not a single issue with this truck. It has had good maintenance. However, I am getting a PO732 and the car seems as if it has no power.
The transmission fluid had not been changed in about 50k. So, I changed it and it actually made it worse. I'm thinking even though the fluid was old, this came all of a sudden. I never had any clucking noises and it shifted smooth as butter.
So, I think it's something electrical.
1. Changed fluid and filters - kind of made it worse
Possible Next steps
2 . Replace Speed Sensors
3. Change shift solenoid
4. Replace Transmission Control Module
4. Worse Trans rebuild? - it just doesn't seem like it needs it. When manually shifting it still drives fine.
I keep hearing all sorts of answers, but there is always a percentage of specific failures. With this code what is the most common problem?
Not the possibility, But the most common. Because this is a big decision. Get rid of it or keep it. I have another vehicle I only use this to haul and pick stuff.
spend somewhere around $500-600. But, I am not spending $3000-4000k for this vehicle.
So, based on that code what percentage has the highest rate of failure?
Possible Next steps
